Modernizing the look of "Crank Yankers"
CharlesPapert
Director of Photography
My day job since May has been on the reboot of the popular Comedy Central series "Crank Yankers", which premieres tonight (9/25). Prior to this I had done a couple of things with puppets here and there, including a day with the Muppets on Scrubs forever ago, but this was the real deal. All puppets, all the time...no human actors.
The original show aired in the early to mid 2000's in standard def of course, and was shot on 2/3" ped cameras in multicam broadcast style. The main note from our showrunner Jonathan Kimmel was to make it more cinematic, so obviously we had room to improve on the camera end. We opted for Varicam LT's with Cabrio 19-90's and an Angenieux 24-290.
After I was hired I visited our new home, Stage 2 and 2A on the historic Sunset Las Palmas lot, a 100 yr old complex that was once owned by Howard Hughes (and where many iconic series and movies have been shot, from the Burns and Allen show, the Addams Family, Beverly Hillbillies to the first two seasons of I Love Lucy--that last one on our very stage). As much as I loved the history, these are notably small soundstages. The original plan was two use Technojibs to allow the camera free movement around our sets that are all raised approximately 4' off the floor to give the puppeteers room to walk around, but their footprint was simply too large. I spec'd Chapman Miniscope 7's, which are one of the smallest telescoping jibs out there. My key grip recommended stabilized heads on these from his experience, and the most cost effective would be a gimbal (we ended up with Movi Pro's) with the Klassen wheels. Varicam LT's fit the size and weight requirement and also the budget, compared to Arri Minis. In addition, I knew I could leverage the high ISO in various ways as described below.
In the previous incarnation, they shot four phone calls a day, which meant 8 sets (the caller side and the mark side). Apparently this led to a long and sometimes trying day. The decision had been made to split forces into two adjacent stages, with two calls on each stage, with separate directors and camera crews for each. The complication was that I was to oversee both stages simultaneously, with one grip and electric crew. I have had moments in the past where I've split A and B camera to different sets in a last minute rush to make a day, but never worked this way fulltime. It required some thinking outside the box! Where I ended up was positioning my cart in a central location so I could walk over to either set easily enough, while monitoring both. I had the sound department (no location audio is recorded, it's all playback of the pre-recorded calls) set up a "god mike" at each video village so I could hear what was happening on stage and be able to respond via walkie to my operators or in person. That audio is imbedded into the SDI feeds that arrive at my cart, where they are accessed by the ATEM TV Studio HD I use as a source switcher, with the audio-follows-video function activated. A small Comtek transmitter takes that switched audio feed and transmits it to a receiver on my belt. The result is that as I switch my monitor feed to a given camera, I will hear the audio from that stage including playback and notes being given. It has worked out remarkably well!
Building on my early experiences with the Varicam, we generally light the sets to a 2.8 1/3 at 2000 ISO (dialed down from the native 5000 ISO setting). This gives an image as clean as the native 800 but allows us to use less than half the light level required for 800. This helps with the size of our lighting package. There are a lot of visual jokes built into the sets via set dressing (usually signage) and often the directors will want to hold focus on these behind the characters, so we will either light those sets to a higher stop (determined at the beginning of the day) or I simply have the cameras cranked up to 4000 or 5000 ISO to pick up more stop. While the shallower depth of field of the S35 sensor helps a great deal with the cinematic vibe, it can be complicated as we also have a fair amount of blue and green screen work and we have to be careful to avoid soft backgrounds around those elements to help with compositing.
Our lighting is a mix of old and new. We have Skypanels, Quasar tubes, Litemats and Source 4 Lustres, but we have to supplement these with legacy tungsten instruments to fill things out. For a given week, we prelight 12 sets and while certain units are moved around on the floor as needed, anything flying from the grid needs to live there for the week or until de-rigged after a set is shot out.
One extra credit situation that I found myself in during prep was helping organize the dozen plus monitors dedicated for the puppeteers (any given setup requires 4-8 monitors to be placed around the set). They had specific requirements for us in terms of working height and portability and I had to work out a formula for these that would satisfy their needs but also help production with the costs. I started testing various 24" TV's and computer monitors and eventually settled on a 24" Vizio that was 1920x1080 (which is becoming more rare in that size), had very little latency and was affordable. We added Blackmagic SDI to HDI converters for each, built looms with power and SDI cable and mounted them via telescoping risers onto small rolling luggage stands I found on Amazon. A central rolling DA station provides power and video ports for each monitor. Coordinating and building out all of these monitors was a large part of my prep. It helps that I am a tinkerer!
As of now I've seen the first four episodes and can report that old fans of the show will likely not be disappointed, a lot of the returning voice actors and characters and certainly the same spirit. I hope that the increased production value will be appreciated!
Sounds fascinating Charles! Thanks for the write up. Are there any grabs or bts stuff that you can share?
Being between the two stages, were you able to have your cart setup permanently there for the duration? Or were you having to roll it out each day?
My cart lives pretty much in the same spot on stage full time which is nice. One of the great things with the show is that it is all contained to these stages, so we have weathered the hot LA summer very comfortably!
Here are some pics of the Varicam on the Miniscope, and also one with C camera below it (which comes out very occasionally for specialty stuff).
I shot with the Muppets twice in the early 2000's with one of those times being at Henson Studio's. Still one of the highlights of my career. Being from the generation that grew-up watching the original TV show made it that much cooler.
I have seen some previews for the return of the show during the last week or so. I remember the original run. I'll have to remember to flip over and check it out, or DVR it.
Is that a regular movi pro.. or movi XL? quite a weight!
How do you operate the head? I use a mimic on sticks.
Regular Movi Pro. Our A cam op owns both of them and has been involved with Movi since their beginning. He said the weight is fine, it's the weight distribution and length of the camera that is right on the edge. The back end of the camera and counterweights just barely clear.
We have the Klassen wheels for the operators. There is a lot of finesse to operating with puppets...the puppeteers heads are just barely below frame, plus seeing off the set at the bottom is always a risk. The operators and crane grips have their work cut out for them.
Are you shooting in 4K to allow for any reframing in post if necessary so that a good performance could be saved if there was a framing slip?
Excellent question. We finish in 1080 and by request of the post department to save storage, we generally shoot in 1080 (ProRes4444) but there are time where we know that punching may be required so we shoot 4K at those times. Occasionally we discover a little bit of "bad stuff" at the very bottom of the frame during the finishing process but we just do the slight blowup in 1080 as required.
Thanks for sharing this Charles, very interesting write up, setup and job. Is Adam C involved in this iteration?
I've only worked with puppets once. I directed and produced a pretty high end corporate film that was an homage
to Thunderbirds, which I loved as a kid. This was back in the days, about 20 years ago when corporate media had real budgets and I
was allocated $350,000.00 to create a national sales meeting opening film that had a live audience of about 3,000, but
was also satellite uplinked live to another 15,000 employees all over the world.
I hired a special effects house in LA to construct the marionettes and to hire
the puppeteers. We had a full cast of human marionettes, plus a dog and a robot. We shot five different sets to make up
an epic journey/battle in outer space. I shot it on 35mm film on a single Arri BL-4, using a crew of 25.
I couldn't agree more, working with puppets is difficult and for my space adventure, these were marionettes with strings above and sometimes
rods from the sides and below so getting them to move in the way that I wanted them to for the story was exceedingly difficult. Making that little
10 minute film increased my respect immensely for what Gerry and Sylvia Anderson accomplished in the Thunderbirds episodes,
Thunderbirds was kind of genius and still stands up, in its own campy and weird British way today. I'm still a fan.
I can't comprehend the amount of multi-tasking you must have had going on at your cart and running through your head. Always appreciate you
sharing your experiences with us, you work on some really interesting content and your insights are always intriguing. At some point,
I will probably write a story on the new BMD ATEM switcher, probably early next year, it would be good to get a few quotes from you and some
BTS snapshots that show how you use them for your cart, if you're game?
Yes, Adam Carolla has recorded a few calls and is an EP on the show.
Everything I've heard about marionettes is that they represent a big challenge, especially in quantity--the stories about Team America are legend. I was a big fan of Thunderbirds in my youth. The production design was off the chain on that show.
Re: ATEM switcher, happy to discuss. I use it extensively, not just for switching sources but I take regular frame grabs and bring them into the media pool as lighting and framing references, it's invaluable for that. On Crank Yankers, I have also done on-set previz pulling keys for the blue screen work if we have the background reference stills available.
Very cool. I'll hit you up next year sometime when you have time and we can get a few impressions from you about how you use them.
I had a chance to work with the Chiodo Brothers a few times when I worked at a production company in Burbank, I used to go to their shop over on Flower Street and got to see all of the puppets from Team America close up, this would have been right after they made the film.
They are really creative guys and have done so much stuff that people didn't know they were involved in. Our in-house composer was the composer for Killer Klowns and he was buds obviously with the Chiodos. Some very creative people in our industry. I was lucky enough to shoot some
interviews with the Chiodos sitting down with Ray Harryhausen, who was friends with my boss. I miss those days, Ray was the coolest guy, he gave me a mold taken from the actual Mighty Joe Young model that fit over the armature he made when I did a little bonus piece on Ray and Mighty Joe Young. I still have it in my office.
Our production designer Gary Kordan posted a bunch of behind the scenes photos from this week's episode--very glad he did! It's fun to step back from the sets and see how crazy things get from "floor level" down!
Wow, you had a lot of great experiences! Meeting Ray Harryhausen--legend!
Ray was a true gentleman, probably the most creative individual I have ever met. I shared many a meal with him, interviewed him and just hung out with him quite a few times, he was a legend and an amazing artist.
I have been privleged to work with and get to know many legends in our business but Ray was probably one of the most talented and sort of mythical amongst filmmakers.
Attached is a cast Alginate image of Mighty Joe Young that Ray gave me when we were shooting tabletop of the actual armature he used in the film. For those of you too young to have ever seen it, Mighty Joe Young, made in 1949, was the first real tour de force stop motion animated film.
The film was considered a seminal work by almost all practical effects artists, animators and major filmmakers and Ray was the man who did it, his patience in doing the stop motion, by himself, day after day, was unbelievable.
