bpotter said:You bet, but you'll loose quite a bit of quality. You're stretching the image. You may want to consider reformatting to 4x3 letterbox.
PIMP said:So does everyone agree thats the only option for me. Combining 4X3 footage of close ups into my anamorphic footage. Just shooting full frame and cropping in post.
thanks
David Jimerson said:You don't lose that much, and you're working with exactly the same picture resolution in letterbox mode as you would in cropped full-frame. Besides, if you want to go anamorphic with your DVD, you're going to have to crop the black bars out of the image and stretch it to 16:9 anyway.
Unless you plan to do no editing other than simple cuts (no CC, no effects, no animated transitions, etc.), and never plan to go to widescreen DVD, letterbox mode is pretty much useless, IMO.
Whoaa. Who says the Ananmorphic can't shoot closeups?PIMP said:Since the ANAMORPHIC ADAPTOR cant close up. Is it possible to shoot close ups without the lense. And just uprez those shots to 16X9 to blend with anamorphic footage?
thanks everyone
PIMP
I think you misunderstood David cuz that's what he just said.bpotter said:I'm not questioning you, I'm questioning my own ignorance. When you shoot in letterbox mode on the DVX, doesn't it simply crop the frame as opposed to 16:9 stretched mode where it actually "stretches" the image?
According to Barry Green's book:
"Letterbox just adds black bars over your video, but the center portion is still the full resolution the camera can deliver."
He said the difference would be negligable, not that it wouldn't be there at all.bpotter said:And later:
"Squeeze mode works by chopping off the top and bottom of the image, and then digtially stretching the image vertically. Then, when the image gets displayed on a widescreen TV, the sape of the TV causes the image to get streched out horizontally, giving you a full widescreen picture. Because squeeze mode only uses 75% of the potential resolution (the rest get chopped off the top and bottom), and uses digital resizing to stretch the image, a squeeze mode picture will be lower in solution than the Anamorphic Adapter version."
And later:
