Bruce Watson
Managed to snag a used MixPre-D. Got it feeding my camera directly (no recorder, yet). Used the tone generator to set camera to -12 dBfs when MixPre-D is showing 0 dBu. This in turn drops the noisy hiss from the mic preamps in the camera way down, just like it should. So far, so good.
Now I'm trying to figure out the limiters. If I set them to +6 dBu, that shows up in the camera as -6 dBfs. So that any sudden loud sounds from talent (sudden laugh, clapping hands, setting down a hard object on a hard surface, that sort of thing) should "shoulder off" and not clip. Yes?
But, am I setting the limiters artificially low? I could, for example, set the limiters to +12 dBu, which would show up as +0 dBfs at the camera -- the point where the camera audio starts hard clipping. But that seems too high. Is it?
BTW, the application is dialog, but not narrative. Things like interviews, cooking shows, product demos, etc. Sometimes using lavs on talent (wired and Senn G3), sometimes using boomed (wired) AT 4053b hypercardioid (especially interviews).
So, please help a MixPre-D newbie out here -- what's the "proper" level for limiters when running from MixPre-D straight to camera?
And tell me a little more (the manual is, um, less than forthcoming) about what the limiter actually does. I'm thinking it's basically applying a curve to the incoming signal. Sort of like the way an equalizer does with frequency, but in this case, with the signal power (across all frequencies). Yes? If so, how is this roll off characterized? IOW, how fast is it? Is there a way to set it up so that no matter how much power I feed in, it doesn't exceed, say, +12 dBu output? So that clipping in the camera is impossible? And if that's possible, is it desirable?
