astronaut Member Nov 16, 2007 #1 Just set up FCP 6.0, and now when I got to File > Import ... I don't see the Panasonic p2 option. Any ideas? Am I missing a driver or something? :undecided
astronaut Member Nov 16, 2007 #2 * Not Missing * - renamed * Not Missing * - renamed Ah, just found the answer to my own question. BUT, if you are reading this because you have the same problem. Read on. The Import Panasonic p2 option has been removed in FCP 6.0 and renamed to work with other media. It is now under > Import > Log and transfer. Hope this helps and if this link is still active you can view more info here: http://www.macdisciple.com/2007/01/06/fcp-panasonic-p2-import-improved/
Charlie Anderson Not so clever Nov 16, 2007 #3 Also Shift + Apple + 8 will bring up the window (the log and capture command is Apple + 8)
