It depends on PP. Cinegamma 2 is 320 I seem to remember. Cinegamma 4 is 640 if memory serves me right. ND's are really the best way to control DOF once you have profile you like. Faster ISO that is clean never really hurts in my opinion.
I often use either mattebox mounted ND's or graduated ND's. But sometimes just screw in ones as well instead of the UV filter that lives on all my lenses, so just swap the UV for a .6 or .9 ND and you have in effect lowered the ISO. Circular polarizers also loose a couple stops.
Best advice ever, no matter what the Cam, ISO or Picture Profile: Keep a 4x4 .6 and/or .9 Grad ND in your kit. Knocks the sky down to get you on the road quickly to an extended dynamic range before you ever think of grading.
The lowest ISO setting is 320 in CINE2, 400 in CINE1, and 640 in CINE4, but they all have about the same white clip point, so if you are outside trying to keep highlights from clipping, changing those wont help and I'd recommend CINE4 for its highlight range in that situation despite the seemingly high base ISO. Use ND/iris/shutter from there however you prefer.
