Mini-BNC to Full-size BNC Cables?
powervideo
Does anyone know where I can find high-quality HD-SDI spec mini-BNC to BNC cables (male to male) for the Samurai-to-F3 on the web? This is doing my head in. If any manufactuer wants to make these they will corner the market as I can't find them anywhere. Markertek, B&H, Amazon, etc.... nada. The Samurai comes with two short mini-BNC to BNC cables, but the BNC end is a female meaning you have to use a barrel connector and another cable.
Thanks for looking but no; the B&H cable has a female connector on the BNC end. It still needs a barrel. I need a male connector on both ends to avoid unnecessary links/joins in the cable.
Markertek has a myriad of hd-sdi cabling
Yep, I corresponded with their Custom Metal & Cable Design Specialist, and they have every cable except that one. He said, "We are working on doing these cables in the very near future." You know it though; can't wait...
I think you mean you want a female Bnc to male din connector. You want a short cable to basically adapt the regular cable from a camera right? Or do you just want one cable, ie camera straight into the recorder? I thought that markertek sold both versions. Is it the same din connector that the hyperdeck shuttle uses?
To bad ur not in the states, if its the same connector as the hyperdeck I have all the stuff to make them.
I think you mean you want a female Bnc to male din connector. You want a short cable to basically adapt the regular cable from a camera right? Or do you just want one cable, ie camera straight into the recorder? I thought that markertek sold both versions. Is it the same din connector that the hyperdeck shuttle uses? To bad ur not in the states, if its the same connector as the hyperdeck I have all the stuff to make them.
Both ends have to be male. The supplied cable from Atomos has a male mini-BNC and a female full-size BNC. I want to use one cable (without a join or barrel) into the camera. Looking at the Hyperdeck, I think the micro connectors are different to the Samurai.
