SOLD Miller Solo VJ CF Tripod/Cartoni Focus Fluid Head
Status
Not open for further replies.
Movies by Matt
$1000
Couldnt post pics for some reason. You can see them here:
http://newyork.craigslist.org/mnh/pho/5410681597.html
http://www.reduser.net/forum/showthread.php?140388-Miller-Solo-VJ-CF-100mm-Tripod-Cartoni-Focus-F100-Fluid-Head&p=1584287#post1584287
100mm 3 stage Carbon Fiber legs.
Cartoni Focus F100 100mm 2-22lb
Here's Jarred Land's review:
http://dvxuser.com/articles/cartfocus/
There are two minor issues, but need to be pointed out:
1. The light for the level on the head is out.
2. There was a small Velcro strap that held the legs together and that item is gone.
Other than those minor issues it functions as it should. Head is smooth. All leg stages are working fine. Only reason I'm selling is to downsize to 75mm. Below is the standard info about the tripod and head.
The SOLO VJ with it's carbon fiber/magnesium design achieves incredibly high torsional rigidity with rock solid stability. Boasting an incredible 8" - 73" height range, this 3-Stage ring-locking tripod collapses down to a dwarf-like 25 1/2". Designed for Video Journalists on the run, SOLO VJ is ultra-light and ultra-versatile, utilizing leg-angle locking to eliminate the need for a spreader, and to reduce overall system weight and complexity.
Carbon fiber construction, supports all full size ENG/EFP camcorders
100mm / 4" bowl base
Safe, speedy 3-Stage ring lock leg clamping
Eliminates Spreader with Leg Angle Lock
Maximum height of 73.6-inch
Supports up to 66.0 lb
Spike or wind-down rubber feet
The Cartoni Focus fluid head is the ideal support for the latest DV cameras weighing from 2.2 to 22 lb (1 to 10 Kg).
The FOCUS fluid head is the ideal support for the latest DV cameras weighing from 1 to 10 Kg (2,2 to 22 lbs). Extremely compact and lightweight,the innovative FOCUS features a continuously variable fluid damping system on both pan and tilt movements and an unprecedented patented variable counterbalance which brings its range of use to cover all existing ENG and DV cameras.
The FOCUS head comes equipped with a quick release sliding camera plate, illuminated spirit level and orientable pan bar. Its tilting angle is +/-90 ° with perfect response throughout the entire tilt range. It interfaces with all 100mm bowl base tripods and supports.The extreme ruggedness and versatility together with an outstanding quality/price ratio make the FOCUS the best possible support for NEWS operators and DV videographers.
Payload capacity 2.2 - 22 lbs (1 - 10 Kg)
Weight 4.4 lbs (2 Kg)
Pan range 360 degrees
Tilt range +/- 90 degrees
Counterbalance Continuous
Fluid drag Continuous
Bowl diameter 100 mm
Temp. range -40 / +158 degrees F (-40/+60 degrees C)
Also selling:
Kessler 3' Cineslider:
http://www.dvxuser.com/V6/showthread.php?343653-Kessler-Cineslider-3-*Mint*&highlight=
IDX VL-4SI
http://www.dvxuser.com/V6/showthread.php?343654-IDX-VL-4SI-V-Mount-Battery-Charger&highlight=
Status
