Miller Compas 12 Solo head w/ 75mm 2-stage CF Legs - $2,299
Lightly used (especially the legs). Some bit of wear on where the baseplate screws are but other than that it's peachy. It's a really solid tripod system.
PM or call 512-440-1400 for details.
The Compass 12 Solo 75 Carbon Fibre syslectable smooth pan/tilt drags, illuminated tem consists of the newly released Compass 12 fluid head and the ultra light yet rigid Solo 75 2-Stage Carbon Fibre Tripod. The system is designed to suit payload capacities from DSLR to DV camera set-ups with features including sebubble level, concentric self adjusting leg locks, light and high strength telescopic tubing and minimum travel length all offered in cost-effective system packages. This is the choice for DSLR/DV professionals on the go!
- Three selectable positions of drag plus a zero position
- Four selectable positions of counterbalance for payloads between 2-10 kg / 4.4-22 lbs
- Quick release sliding camera plate with 60mm travel
- Illuminated bubble level
- 75mm Ball levelling
- Solo 75 2-Stage Carbon Fibre tripod
- 3 Position Leg angle locks for a height range 404-1784 mm / 15.9-70.2"
- Spikes with wind down rubber feet
