[FS: General] MILLER arrow 40 (#1025) / Sprinter II Tripod (#1576) 2-Stage Carbon Tripod
yantiadam
Please go to the following link to ebay to buy :
http://www.ebay.com/itm/20068739383...X:IT&_trksid=p3984.m1555.l2649#ht_1008wt_1189
Only used twice. Previous owner typically uses motion control instead of manual panning – in absolutely perfect working condition. Includes Arrow 40 fluid head, and camera plate, original travel packaging and all documentation. Also comes with 2 spare camera mounting plates.
For faster shipping with Fedex, please contact me for rates.
Total weight : 10.2kg/ approx : 22lb
Please note : We will not be responsible for any local customs taxes and charges when the item arrives in your country.
Arrow 40 (#1025)
The Arrow 40 fluid head performance and features has evolved from the demanding world of news gathering. Strength, durability and smooth fluid action have been combined in a simple-to-operate fluid head offering 7 positions of pan and tilt drag in addition to its many other features. The Arrow 40 offers the widest range and heaviest drag in its class. From fast-action sports shooting to long, slow pans the Arrow 40 exceeds expectations of precision, quality and features for the ENG operator.
Features:
Payload ranges from 7–16kg
7 (plus zero) positions of fluid pan and tilt drag
4 positions of counterbalance
70mm Quick release sliding platform
100mm ball levelling
Rear mounted controls
White illumination of bubble level and indicators for pan and tilt
Sprinter II (#1576) 2-Stage Carbon Tripod
The new Sprinter II ENG tripod range features Miller Sprint-Loks- Dual, side-action leg locks that let you independently adjust both stages of a 2- stage tripod using one hand. Each tripod leg has two Sprint-Loks, co-located on the upper leg clamp. The result: high speed adjustment, no more bending down to adjust the lower tripod stage.
Features:
  • Easily accessible, high speed dual action locks
  • Lightweight and rigid tripod construction
  • Tripod models suits fine height adjsutable mid level spreader
  • Inline carry handle
  • Compatible with #475 Forever-flat rubber foot design
  • Rapid action transport clips
Specifications:
Spreader Type:Mid Level SpreaderTripod Series:Sprinter Tripod Series
Transport Length:700 mm (27.6 in)Payload Capacity:45.00 kg (99.2 lbs)
Minimum Height:440 mm (17.3 in)Maximum Height:1530 mm (60.2 in)
Material:Carbon FibreLock Type:Sprint-Loks
Construction:2-StageBowl Diameter:100 mm (3.9 in)
Weight:2.90 kg (6.4 lbs)
