therager
I'm letting go of this fantastic tripod because I had to purchase a 100mm system.
I've had this system for around 2.5 years and I've loved every shoot I've done with it. It has such a fantastically smooth feel to it, and it performs just like it did when it was brand new, so these things last! If you are looking to upgrade your tripod, this Miller is a really great option. It's showing some cosmetic wear, but that will not impact the performance at all.
The foam that goes around two of the legs ripped down the middle over time, so I taped around the foam to make sure they stay in place. This hasn't been a problem at all. This does not affect the performance of the tripod, nor does it prevent the foam from protecting the legs. It is also just cosmetic. Please see the photos attached.
The bag has the handles but not the strap that came attached originally.
All of the features and specs can be found at the Miller website, but here are some of the highlights:
Asking $1,700 plus shipping.
- Two-stage, telescoping design of carbon-fiber construction. Leg angle locks are available for height adjustment.
- Five selectable positions of high performance drag plus a zero position
- Selectable counterbalance system for payloads between 2-10 kg /4.4-22 lbs
- 60mm (2.4") sliding camera plate
- Solo DV 2-Stage Carbon Fibre tripod
- Leg angle lock for 234-1614mm / 9.2-63.5" height range
- Spike/Rubber feet support
- 75mm ball levelling
