Not sure about the GL1, but the GL2 has manual audio level controls... but no line input, just that cheezy little mini-stereo...
Six of one, half a dozen of the other. Avoid anything with a built-in preamp, as the GL1's preamp is stuck in the "on" position. If phantom power becomes an issue, there are plenty of battery-powered +48V phantom power supplies on the market (I'm pretty sure PSC makes one). However, the real weak link in your audio signal chain will be the GL-1. With that AGC, the levels will be up and down like a toilet seat (ie. pretty much useless for pro work).So again... Beachtek or Juicedlink.
I wasn't aware that the GL-1 had manual audio controls. Thanks for the correction.AGC on the GL-1 can and should be turned off.
One-man-band shooting doesn't neccessarily preclude double-system shooting. A Zoom H4 doesn't weigh much more than the first generation of Beachtek adapters, although slating and maintaining synch can be a challeng.Double-system would be heaps better, but if you are a one-man run-and-gun operation, you do what you have to do.
