jredmond108
BASIC JIB KIT
The Basic Jib Kit includes the MICRODOLLY Jib and the standard 34 inch MICRODOLLY Soft Case. An adapter plate to attach the Jib to almost any professional tripod and a heavy-duty camera plate knob to mount the camera are also part of the Kit. Spring-loaded clips are included to keep gym weights safely on the weight bar. To increase reach, the Jib boom can telescope from 33 inches to 52 inches. The Jib weighs just over 9 pounds and will carry a maximum video or film camera load of 50 pounds at the 33 inch length. No tools are required to assemble.
This innovative Jib Arm will easily handle most professional film and video cameras. Gym weights may be used, or a sturdy folding Weight Cage accessory will hold anything you have for counter-weight: rocks, sand, even water! Jib can be set to automatically adjust the camera "tilt" or "Dutch" angles as you move. Features adjustable tilt and pan friction drag controls. Bubble level is on the yoke base. Camera plate is also adjustable for level. Dual bumpers are on the yoke base for protection.
Net Weight: 11.5 lbs. (5.21 kg) Including the Soft case
JIB UPGRADE KIT
The Jib Upgrade Kit includes the most popular MICRODOLLY Jib accessory items. The Kit contains the Weight Cage, a nylon cage liner bag and a folding water bottle, a 30-inch Boom Extension, the stainless steel Boom Truss, and the Multi Joint Monitor Mount. A MICRODOLLY Soft Case bag provides convenient storage and handling. Please look below for details and specifications of each accessory.
Net Weight: 12 lbs. (5.44 kg) Including soft case
JIB DOLLY
The Jib Dolly is designed to support any size MICRODOLLY Jib. Manufactured from structural grade aluminum and hard anodized for weather protection, it has nine large heavy-duty ball bearing wheels that provide an extra large foot print for added stability. A telescoping steering and pull handle make it easy to move even when fully loaded. For safety, all wheel casters have quick-release brakes. The Jib Dolly folds for easy transport and comes with a heavily padded softcase.
Net Weight: 18 lbs. (8.16 kg)
Everything is in excellent condition. I am retiring. New all of this would be around $5,000. Will take $3,400.
JIB UPGRADE KIT
JIB DOLLY
