Nick Mirro
I'm a beginner to xlr sound with a very small budget and I am wondering if these two mics would work with the inexpensive field mixer below. The goal is to combine 2 channels of stereo from the stereo lapel mic (that I have) with the output from the Audio Technica.
Will the mics below work with this mixer?
I know this is low budget cobbled together rig, but it is all I have. Thanks for any help!
ROLLS MX124
http://tinyurl.com/c8bavhc
Input Connections 4 - 3-pin XLR female
Output Connectors 2 - 3-pin XLR male
Max Input/Output Gain +55dB
Input Impedance: 600 Ohms
Output Impedance: XLR 500 Ohms
Signal-to-Noise Ratio 84dB
Phantom Power +18V DC
AC Power Requirements x2 9-Volt Alkaline Batteries
Current Draw: 30mA
Dimensions 6.3 x 2.3 x 3.7" (160 x 58.41 x 93.98mm) (WxHxD)
Weight 1.5 lbs (680.38 g)
AUDIO TECHNICA AT875
Transducer Fixed-charge back plate, permanently polarized condenser
Polar Pattern Line + gradient
Frequency Response 90Hz - 20,000Hz
Dynamic Range (Typical) 107 dB, 1 kHz at Max SPL
Sensitivity -30 dB (31.6 mV) re 1V at 1 Pa
Impedance 100 ohms
Signal-to-Noise Ratio RATIO 74 dB, 1 kHz at 1 Pa
Maximum Input Sound Level 127 dB SPL, 1 kHz at 1% T.H.D.
Power Requirements 11-52V DC, 2 mA typical
Output Impedance 100 ohms
Output Connectors Integral 3-pin XLRM-type
Phantom Power 11-52VDC, 2 mA typical
Dimensions 6.89" (175.0mm) Long
0.83" (21.0mm) Diameter
Weight 2.8 oz (80 g)
Olympus ME51S
http://tinyurl.com/8wlpoym
(using a Y-adapter)
Type Stereo Electret Condenser Microphone
Frequency Response 100Hz - 15kHz
Directivity Uni-directional x 2
Sensitivity -40dB @ 1kHz
Impedance 2.2 kOhms
Plug 3.5mm Stereo
Power Supply Plug-in-power System (1.5V - 10V)
Dimensions (L x B x H)
1.5 x 0.55 x 1.6" (38 x 14 x 40mm)
Weight 0.24 oz (7 g), 0.6 oz (18 g) with cable and clip
ROLLS MX124
Current Draw: 30mA
Impedance 100 ohms
Olympus ME51S
(using a Y-adapter)
Impedance 2.2 kOhms
Plug 3.5mm Stereo
