spotlightpro
Have checked with so many different forums and asked so many different people this question, and have not gotten a helpful answer yet... I will go step by step so maybe you can see where I am going wrong. I capture all my footage via firewire into avid. I edit my sequences then export the sequence as a qt reference (this should be lossless, correct?) I import the qt reference into sorenson squeeze 4, and customize a DVD_Large_NTSC so my bitrate is higher (ie 8000), I click off de interlace. My audio and video are then compressed and encoded to .mpv. I take this file to author in Ulead's DVD Workshop2. It then seems as though DVD Workshop then encodes the files again when I am trying to burn it to DVD. I use highest quality settings all the way through. My final output is decent but nowhere near some of the other footage I ahve seen burned to DVD from even inferior software. I know I can get more beautiful footage from My DVDs I just don't know where I am going wrong. Too many steps. DVD Workshop2 has its own transcoder should I just send the footage directly to it? What would the point of having Sorenson squeeze even be at this point? Any comments would be much appreciated. Thanks so much!!!
