I have a few quick questions. We're shooting an educational web series with two individuals in front of a workbench, approximately 6ft long. Both looking directly at the camera. Distance between the individuals is going to be roughly 3ft. My equipment options are Juicedlink little darlings on each individual, or SD633 with mic. I prefer to use the SD633. I have a Sanken CS-3e mic; but, I don't think that would be a good option for picking up both individuals. It's pick up is surgical. Location doesn't really allow for hiring a boom op as a long term solution either, so the mic needs to remain static. I do have an AT875r as well, but I'm thinking of purchasing another mic that is better suited for indoors anyway. This location is an aircraft hangar. It's all metal and concrete, and there's nothing in there to prevent reflection. Other locations that I'm frequently in are often smaller rooms. The CS-3e is my go to when outdoors, which is usually at an airport. My questions are as follows:
Is it reasonable to use the Schoeps CMC6 MK41 boomed in front and overhead for both individuals, or would it most likely be necessary to us separate mics on each individual?
Is the CMC6 still considered a great mic for small rooms, like an office?
Would there be any issues pairing the CS-3e and CMC6?
Are there mics, other than the CMC6 Mk41, that I should consider for indoor shots? The CS-3e will likely remain my go to for outdoors.
