FS7: Mic mount Replacement Options
AMcBroom
So my mic mount is finally completely hosed. What replacement options are there? I'd look at replacing the top handle as well if needs be. Thank you in advance.
I use the Shape light weight top plate, which fits snugly and has an array of 1/4-20 threaded holes. This has allowed me to attach a small cold shoe adaptor with thumbscrew clamp (from SmallRig), into which I can easily attach any shock mount, I use the one supplied with my Ambient TinyMic (which is amazingly good for the size and price BTW). This has the added benefit of keeping the mic in more-or-less the same position as it sits with the factory 'shock'-mount. Here's a pic:
I'm interested in replacement top handles too, but am too reliant on the XLR-K1M unit that uses the MI shoe on the handle. Building up the courage to do some surgery and CNC myself a new PROPER handle ;-).
Good luck,
jason
I've replaced the rod with the mount on with a smallrig rod that has some threaded holes on one side of it. I've stuck a hotshoe adapter on there and then I can just add or remove an ebay hotshoe suspension mount as and when I see fit, and still have the MI shoe available for my Sony wireless kit. works perfectly
