GH4 Metadata - what's retained?
mcbob
So I have a few shots from an earlier project for which I didn't keep excellent notes, and now I have need to match it for additional material.
Given a 4K .mov file, is there any way to recover information about shot profile, etc?
...and yes, I have been and will be keeping better notes in the future.
bundled software? Was there a DVD in the box that I tossed in a storage bin along with all the other packaging and documentation?
edit... hm, so there was.
So I dug up the old DVD, then dug up an old laptop with an old optical drive and loaded "Silkypix" onto my iMac. Can't open a dang thing except the camera raw files. Was there another bundled software you meant?
It's called PHOTOfunSTUDIO 9.5 PE. I uninstlled it as it's not very friendly and doesn't have the one piece of information I most often can't remember. ISO of course :)
It does show ISO for still though.
Cheers,
Pete
Yes, Exiftool works and every piece of information you'd need is there, ISO, shutter speed, white balance, picture profile, even sharpness and contrast settings although they aren't numerical for some reason. Took a while for me to figure out so for people on on OS X, install the package, open terminal and type: exiftool (leave a space after exiftool, then before hitting return drag your mov file into the terminal window. It will leave directory info for your clip. Hit return and it should spit out a list. This is what a list looks like from one of my clips. Exposure and focal length says ZERO because I was using a manual lens.
File Size : 106 MB
File Modification Date/Time : 2014:06:23 14:07:54-06:00
File Access Date/Time : 2015:02:11 07:49:13-07:00
File Inode Change Date/Time : 2014:06:23 14:16:08-06:00
File Permissions : rwxrwxrwx
File Type : MOV
MIME Type : video/quicktime
Major Brand : Apple QuickTime (.MOV/QT)
Minor Version : 2011.7.0
Compatible Brands : qt , pana
Movie Header Version : 0
Time Scale : 360000
Duration : 11.00 s
Preferred Rate : 1
Preferred Volume : 100.00%
Preview Time : 0 s
Preview Duration : 0 s
Poster Time : 0 s
Selection Time : 0 s
Selection Duration : 0 s
Current Time : 0 s
Next Track ID : 4
Track Header Version : 0
Track Create Date : 2014:06:23 14:07:54
Track Modify Date : 2014:06:23 14:07:54
Track ID : 1
Track Duration : 11.00 s
Track Layer : 0
Track Volume : 0.00%
Image Width : 4096
Image Height : 2160
Graphics Mode : ditherCopy
Op Color : 32768 32768 32768
Compressor ID : avc1
Source Image Width : 4096
Source Image Height : 2160
X Resolution : 72
Y Resolution : 72
Bit Depth : 24
Color Representation : nclc 1 1 1
Video Frame Rate : 24
Time Code : 3
Balance : 0
Audio Format : twos
Audio Vendor ID : Panasonic
Audio Channels : 2
Audio Bits Per Sample : 16
Audio Sample Rate : 48000
Matrix Structure : 1 0 0 0 1 0 0 0 1
Media Header Version : 0
Media Create Date : 2014:06:23 14:07:54
Media Modify Date : 2014:06:23 14:07:54
Media Time Scale : 360000
Media Duration : 11.00 s
Media Language Code : und
Gen Media Version : 0
Gen Flags : 0 0 0
Gen Graphics Mode : ditherCopy
Gen Op Color : 32768 32768 32768
Gen Balance : 0
Text Font : System
Text Face : Plain
Text Size : 12
Text Color : 0 0 0
Background Color : 0 0 0
Font Name :
Handler Class : Data Handler
Handler Type : Alias Data
Other Format : tmcd
Exif Byte Order : Little-endian (Intel, II)
Make : Panasonic
Camera Model Name : DMC-GH4
Orientation : Horizontal (normal)
Resolution Unit : inches
Software : Ver.1.0
Modify Date : 0000:00:00 00:00:00
Y Cb Cr Positioning : Co-sited
Exposure Time : 1/25
F Number : 0
Exposure Program : Manual
Exif Version : 0230
Date/Time Original : 2014:06:23 14:07:54
Components Configuration : Y, Cb, Cr, -
Compressed Bits Per Pixel : 2
Exposure Compensation : 0
Max Aperture Value : 1.0
Metering Mode : Multi-segment
Light Source : Unknown
Flash : Off, Did not fire
Focal Length : 0.0 mm
Image Quality : Unknown (13)
Firmware Version : 0.1.0.0
White Balance : Auto
Focus Mode : Manual
AF Area Mode : Unknown (0 49)
Image Stabilization : Off
Macro Mode : Off
Shooting Mode : Movie Preview
Audio : Stereo
Data Dump : (Binary data 8 bytes, use -b option to extract)
Flash Bias : 0
Internal Serial Number : (X15) 2014:04:11 no. 0041
Panasonic Exif Version : 0407
Color Effect : Off
Time Since Power On : 00:00:22.60
Burst Mode : Off
Sequence Number : 0
Contrast Mode : Unknown (0x3)
Noise Reduction : Standard
Self Timer : Off
AF Assist Lamp : Disabled and Not Required
Color Mode : Normal
Optical Zoom Mode : Standard
Conversion Lens : Off
Travel Day : n/a
World Time Location : Home
Program ISO : 400
Advanced Scene Type : 10
Faces Detected : 0
Color Temp Kelvin : 3200
Bracket Settings : No Bracket
WB Shift AB : 0
WB Shift GM : 0
Flash Curtain : n/a
Long Exposure Noise Reduction : On
Panasonic Image Width : 0
Panasonic Image Height : 0
AF Point Position : none
Num Face Positions : 0
Lens Type : NO-LENS
Lens Serial Number : 0000000
Accessory Type : NO-ACCESSORY
Accessory Serial Number : 0000000
Lens Firmware Version : 0.0.0.0
Faces Recognized : 0
Title :
Baby Name :
Country :
State :
City :
Landmark :
Intelligent Resolution : Off
Burst Speed : 0
Intelligent D-Range : Off
Clear Retouch : Off
City 2 :
Photo Style : Natural
Shading Compensation : Off
Accelerometer Z : 280
Accelerometer X : -6
Accelerometer Y : 29
Camera Orientation : Normal
Roll Angle : 0.4
Pitch Angle : -0.8
Timer Recording : Off
Internal ND Filter : 0
HDR : Off
Shutter Type : Mechanical
Clear Retouch Value : undef
Touch AE : Off
Maker Note Version : 0147
Scene Mode : Off
WB Red Level : 2005
WB Green Level : 1024
WB Blue Level : 2834
Flash Fired : No
Text Stamp : Off
Baby Age : (not set)
Sub Sec Time : 713
Sub Sec Time Original : 713
Sub Sec Time Digitized : 713
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 4096
Exif Image Height : 2160
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Auto
Digital Zoom Ratio : 0
Focal Length In 35mm Format : 0 mm
Scene Capture Type : Standard
Gain Control : High gain up
Contrast : Normal
Saturation : Normal
Sharpness : Normal
PrintIM Version : 0250
Compression : JPEG (old-style)
Thumbnail Offset : 11924
Thumbnail Length : 0
Movie Data Size : 111237184
Movie Data Offset : 262152
Advanced Scene Mode : Unknown (0 10)
Avg Bitrate : 80.9 Mbps
Blue Balance : 2.767578
Image Size : 4096x2160
Megapixels : 8.8
Red Balance : 1.958008
Rotation : 0
Shutter Speed : 1/25
Create Date : 2014:06:23 14:07:54.713
Date/Time Original : 2014:06:23 14:07:54.713
Modify Date : 0000:00:00 00:00:00.713
FYI, on Mac OSX I tried one of the GUI interfaces for exiftool but it kept crashing everytime I tried loading a MOV file, so it's only terminal for now. I hope they update FCP X to take advantage of this metadata, as it would be useful.
Splendid, that worked (kind of... now to translate "soft" into a number....) Thanks triple much all!
If you use a LUMIX lens there is even more useful info, including crop factor and 35mm lens equivalent focal length.
Lens ID : LUMIX G VARIO 14-42mm F3.5-5.6
Preview Image : (Binary data 988006 bytes, use -b option to extract)
Megapixels : 14.2
Red Balance : 2.419922
Scale Factor To 35 mm Equivalent: 2.1
Shutter Speed : 1/60
Create Date : 2014:07:23 14:24:06.847
Date/Time Original : 2014:07:23 14:24:06.847
Modify Date : 2014:07:23 14:24:06.847
Thumbnail Image : (Binary data 8364 bytes, use -b option to extract)
Circle Of Confusion : 0.015 mm
Field Of View : 23.4 deg
Focal Length : 42.0 mm (35 mm equivalent: 87.0 mm)
Hyperfocal Distance : 21.72 m
Light Value : 9.9
So Photo Style: Unknown (9) = Cine V and Unknown (8) = Cine D. I'll update as I decipher "low" vs. "soft" vs. whatever else
