Erik Naso
I've recently picked up a few Contax lenses to use with the GH5. I have the 35mm 2.8, 50 f1.4, and 85mm f1.4 . So far I like them a lot on the C300 with adapters they are very nice. On the GH5 with EF Mount adapters and a EF to MFT Speed Booster XL the infinity focus is off. The 35mm is really bad. and the 50mm is fair. Longer lenses tend to work better with adapters from what I understand. The 85mm is very usable but I still can tell it's not hitting infinity. I pulled out a Canon 35mm L to test and it's not as bad as the Contax but again I can tell it's off. I have to assume the Leitax permanent EF adapters
are not helping with the issue on the Contax/Speed Booster combo.
I then put the Duclos Tokina EF 11-16 on the Speed Booster and it's very soft and unusable. Wide open at 2.8 it's just plain unusable.
Is this common? I attempted to adjust the infinity focus on the adapter but was only able to adjust the element less than a 1/4 turn. Probably 1/8 is more like it. Seems to be at it's end of adjustment setting.
I have to admit i'm very disappointed. Metabones recommends the XL over the ULTRA for the GH5. I figured it would be compatible with more than a 50mm lens. The other bummer is Metabones customer service is very bad. I emailed them a few days ago and havent heard back. I wish another company would make these focal reducers. At $650 you would expect a little more.
So is it broken? Are you experiencing Speed Booster XL heaven with your GH5?
