Just used the merlin with the HVX200 on a shoot.
No problems balancing. I tried the cookbook settings which i did not have much luck with.
This setup is with one 4gig card in bottom slot. Lens hood on. No filters. 2800mah Panasonic battery CGP-D28 ($78 buy .com) . Lcd screen open. No extra washer weight was needed. Nothing else on camera.
For those that care: Plate hole H, 1 finish weight on front, all the other weights on bottom spar, arc size from mount plate to bottom spar set screw 14 inches, Z axis -3 turns from top, G-plat- yes, stage mark on lcd side +3.
When not working I go to the gym, I do weights , hit the bag , do some ground grappling so the weight didn't kill me. 5, close to 20 sec. shots 3 takes each with some rehearsals thrown in on flat ground. No problem. Did some tests going up and down 3 flights of stairs and started to sweat it because of having to continuously hold and re trim tilt for going up and for going down and tight turns which i couldn't get the hang of trying to keep the cam level while moving quickly.
2 handed hold helps weight issue with 2nd hand taking just a bit of weight so light touch forefinger and thumb can hold slight swing or pan.
Overall i reallly like the merlin. After a couple of hours, trimming and setting up become real easy. You come to know what you need to do quickly. Very well thought out and compact.
