The Engineer said:The humming noise is a new well known Panasonic problem. It is the video heads which is consumer stock - it is not a true professional unit like the DVCPRO cameras have. They have started using these heads when they've launched the DVC30 camera - we had huge problems with head noise on those, up to -46dB humming. The noise goes away in VCR mode simply because heads stop spinning in STOP mode. As I said before, Panasonic is in the business of making money and one way is to use a $150 part instead of a $700 one. Use the camera (which is great BTW) with an external microphone if live sound is so vital.
Jan, your position is very legitimate indeed. However, I assume that so-called "non professional" (read "non-DVCPro") parts were used in the 100A as well, and my 100A seemed (I repeat seemed) less noisy than my current 100B.Jan_Crittenden said:There is no way that you should even begin to compare the transport on a DVCPRO camcorder with the DV mechanism, it is not a fair test.
