[FS: General] MAUDIO Lightbridge $275
morgt0
MAUDIO Lightbridge $275 Excellent condition – used once for a special gig. Original box, manuals and all cables\accessories.
The ProFire Lightbridge from M-Audio is a FireWire interface, capable of connecting up to four Lightpipe equipped devices, such as an eight-channel preamp, to a PC or Mac computer. The unit provides a total of thirty-four digital inputs and outputs, plus two analog outputs over a single FireWire connection, and is perfect for integrating digital mixers, AD/DA converters and/or ADATs with DAW software.
The interface also supports sixteen-channel Lightpipe operation at 88.2 and 96kHz sample rates via the SMUX protocol. Additionally it can output Wordclock as a master, or slave to external sync on any input. The MIDI I/O, available on an included breakout cable, also accommodates MIDI Time Code and MIDI Machine Control. Independent volume controls are provided for the balanced outputs and front panel headphone jack.
FireWire computer audio interface with four ADAT optical Lightpipe inputs and outputs
Two channels of coaxial S/PDIF I/O
Stereo balanced 1/4" analog outputs with dedicated level control
All inputs and outputs can be used simultaneously
Front-panel stereo headphone output with dedicated level control
Optical ports are S/MUX capable for high-resolution audio
Supports sample rates of 44.1, 48, 88.2 and 96kHz at up to 24-bit resolution
Word clock I/O on BNC connectors
Sixteen channels of MIDI I/O with activity indicators
Activity LEDs show enabled ports and valid data at the optical I/O ports
Sample rate LED and Wordclock source LED indicators
Converters24-bit
Sample Rates44.1, 48, 88.2 and 96kHz [SUP]1[/SUP]
Analog InNo
Analog Outputs2 x 1/4" TRS phone
Digital Input Connectors4 x ADAT Lightpipe
1 x RCA coaxial S/PDIF (on breakout cable)
Digital Output Connectors4 x ADAT Lightpipe
MIDI In/OutYes (on breakout cable)
Sync In/OutYes (on breakout cable)
Headphone OutputYes
THD + N0.00127% (-98dB) @ -1dBFS, 1kHz
Dynamic Range109dB, A-weighted
Frequency Response20Hz to 20kHz, +/-0.1dB @ 48kHz sample rate
20Hz to 40kHz, +/-0.2dB @ 96kHz sample rate
Minimum System RequirementsMinimum:
Mac:
PowerMac G4 1GHz (G4 accelerator cards not supported)
OS X 10.3.9 / 10.4.7
512MB RAM
7200 RPM hard drive (8MB buffer)
Native FireWire port
PC:
Pentium IV 1.8GHz
Windows XP (SP 2)
512MB RAM
Available FireWire port or FireWire expansion card
Recommended:
Mac:
G5 Dual 1.8GHz
1GB RAM
7200 RPM hard drive (16MB buffer)
PC:
Pentium IV 2.8GHz
Windows XP (SP 2)
1GBB RAM
Specialties16 channels of MIDI I/O
