[FS: General] Matte box - chrosziel sd 412 sunshade price: $1089
gorannera
MATTE BOX - CHROSZIEL SD 412 SUNSHADE PRICE: $1089
Compact MATTE BOX Sunshade 104mm System (AC-412-02F104), which includes the AC-CLWAH-F4.5 and AC-CF-SS/104 (with a 104mm clamp adapter)
Lightly used for short period of time. In perfect condition and looks like new having few signs of cosmetic wear. Fully operational and functions as intended. Only default - Missing French Flag (Retail price for flag $40 - $50)
Price for a New Matte Box Chrosziel C-412-02F SunShade with a 104-98mm step down adapter and ring is $2006.00.
I'm selling my Matte Box for $1089.
Included in the kit:
1) Chrosziel CLWAH-F4,5: (Compact Large Wide Angle Housing)
2) Chrosziel CF-SS/104: (104mm Clamp Adapter)
3) Chrosziel 410-31: (4x4 /4x4.560 Combo Filter Tray)
5) Chrosziel 510-01: (5x5 / 4x5.650 Filter Tray)
6) Chrosziel 411-29: (104mm > 98mm Step Down Ring)
7) Chrosziel 410-41: (104mm > 98mm Step Down Adapter Ring)
The connecting diameter of 104 mm and the respective Step-Down Rings fit most lenses and various Step-Down rings are available.
For maximum stray light reduction, sets of mattes for 4:3 and 16:9 formats are available.
The included Double Filter Stage takes filters up to 5.65x5.65“.
Both filters slide vertically and can be fixed in any position, the second also rotates 250°.
For optimal use of the picture angle, the filter-stages are equipped with multi format filter-holders for 4x4 and 4x5.65” filters in the first stage and, in the second, rotating multi format filter-holder for 5x5 and 4x5.65” formats.
Insert 5x5“ filters and fully use the wide angle format in any position of the rotating stage. For even more flexibility when using e.g. graduation filters, insert 5x6” filters in the first stage (filter-holder 510-02).
The Chrosziel C-412-02F104 is a lightweight 16:9/4:3 clamp-on SunShade (Matte Box), designed to work with wide range of lens and specifically with wide-angle 2/3" ENG lenses that feature a focal length down to 4.3mm, such as the Fujinon 13x4.5 and the Canon 14x4.3. With a 104mm clamping back, the sunshade reduces glare, which helps eliminate lens flares.
Technical data:
Max. wide angle focus length F=mm
S35 (11) / S16 (6) / still 16 /
SD 3.9 / HD 4.3
Multi-Format 4:3 and 16:9 S16, S35, SD, HD
Mattes 4:3 for F=mm 4,8/10/20/30/48
Mattes 16:9 for F=mm 4,8/10/20/30/48
Max. filter number / rotating / gear positioned 2 / 1 / -
Filter stage width (mm) 150
Filter size (inch) 4x4/4x5.65h + 5x5/4x5.65h
Connecting diameter (mm) 104 / 110 / 130
Support system: Clamp adaptor *
* With Center Bracket
With The Center Adaptor (420-02) also usable on 15 mm rod support, connecting the SD 412 with the Light-Weight- Support
