Matt Gottshalk
Resident Preditor
Works great.
Taken out of a studio environment.
$2395 new.
$1900 shipped.
The MXO2 Rack MAX from Matrox is a complete SD/HD I/O device that combines the functionality of an I/O card in the form factor of a rackmountable, breakout box. This model features Matrox MAX technology for faster than real-time H.264 encoding and is intended for use with PCs or Intel-based MacBook Pros, Mac Pros, and Apple Xserve systems.
This 2RU unit is designed for use in postproduction facilities, broadcast news operations, OB vans, and other environments that can benefit from streamlined workflow with Apple Final Cut Pro or Adobe Premiere Pro. This model additionally features Matrox MAX technology for faster than real-time H.264 encoding. encoding
This unit features multiple audio and video inputs & outputs. Advanced audio functionality includes 5.1 and 7.1 surround-sound monitoring. HDMI video monitoring can be calibrated. 10-bit hardware is included for up-, down-, and cross-scaling. This unit is also compatible with a wide range of common industry file formats and codecs.
Note! Adobe Premiere Pro CS6 support.
Use this unit with a PC or Intel-based MacBook Pro, Mac Pro, and Apple Xserve system
It is housed in a rackmoutable, 2RU form factor
It features SD/HD-SDI, HD/SD analog component, Y/C, and composite inputs and outputs
Genlock with loop through, SD analog black burst (bi-level), or HD tri-level sync are all standard features
It offers HDMI input, output, and monitoring with calibration controls, including blue-only
It includes 10-bit, real-time hardware for up-, down-, and cross-conversion on capture and output
Up to (5) user-selectable simultaneous video outputs are available: HD and/or SD on HDMI, SDI, and analog
Professional audio inputs and outputs include 5.1 and 7.1 surround-sound monitoring:
- 4-input, 8-output balanced XLR
- 4-input, 4-output unbalanced AES/EBU
- 8-input, 8-output SDI and HDMI embedded
RS-422 machine control is included for frame-accurate capture and print-to-tape
Capture to virtually all codecs supported by Adobe Premiere Pro and Final Cut Pro, including Apple ProRes 422 HQ and 10-bit uncompressed HD
File-based workflow supports XDCAM, XDCAM HD, XDCAM EX, P2, and P2HD
RED workflow is supported
HD-SDI closed captioning is a standard feature
It works with Final Cut Pro, Adobe Premiere Pro, Apple Color, Adobe After Effects, and all QuickTime applications that support the V-out component
$2395 new.
$1900 shipped.
