FS7: Matching FX9 to FS7
LennyLevy
Matching FX9 to FS7
I’m wondering if anyone has had good luck trying to get the FX9 to match the FS7 for multicam work in both Custom and Slog. I have a lot of clients with FS7’s and don’t want to lose that work if I sell my FS7. Ideally I want to be able to create a simple setting or LUT that would convert the FX9 the FS7 both in camera and for post if possible. So far I’ve done a lot of tests and the results have been surprising and more difficult than I expected.
Actually Custom turned out be easier for me to match than Log. Cody Flowers and I spent a bunch of time at Eli Adler’s Clean Slate Productions in San Rafael, CA trying to match charts and photos from old Nat Geos with a vectorscope and we discovered that if we used the same Gammas, then the FS7 in “ F55-Like” Matrix seemed a close basic match to to the FX9 in “Standard” . If the FS7 was basically zeroed out ( except -13 Sat) then the FX9 matched if we raised the Sat Level a bit and moved the phase over just by +4. If we wanted to get fancy we could also make a couple of changes with the Multi Matrix to bring the saturation on a couple of colors in line, but both the visual and vectorscope match was quite good.
The rest of the tests I did at my house with a model and a bamboo screen behind that had a whole bunch of different colored fabrics. It was easier to see mismatches with the fabrics than it was on charts. The custom settings worked well right away but Slog3 was literally a slog.
The first problem was getting the luminance levels of the both cameras in Slog3 to match with similar f stops. If you shot the FS7 at 1000 EI, that would be 1 stop overexposed. But the FX9 at 1000 EI on Low base would be 1/3 stop under, and at High base 1000EI would be 2 stops over. What I ended up doing was running the FX9 at high base 2000 EI but shooting through an N3 filter. Now I had both cameras overexposed 1 stop and shooting at the same f stop. However even here, the gamma curves of Slog3 on the FX9 and the FS7 are not identical, so my first step was always to make minor changes to the shadows, gain and gamma of the FX9 to match. (The custom gammas were much more similar.)
At first I tried loading an s709 (Venice/FX9) LUT into the FS7 camera so both cameras used the same LUT burnt-in. That sounded logical, but they just looked different and while white balancing the FX9 helped, it wasn't good enough. Then I tried the same thing in Post, but while I could easily get a grey or flesh tone to match , trying to get both at once and nail all the colored fabrics didn’t work unless I resorted to secondaries on a number of colors. I didn't want to tell a client they needed to screw with secondaries. Same problems using using LC709A for both cameras. I also didn’t have any luck using the auto match features in Resolve for charts or flesh tones, and didn’t seem to get lucky with Aces either - though I'm not experienced with Aces.
I didn’t particularly like the look of the s709 LUT on the FX9 footage anyway. I’ve heard complaints that its too green though to me it felt too Yellow but I think that’s pretty close to the same thing. Noticing the FS7 was too magenta and the FX9 too green/yellow - I had a brainstorm. I switched the LUTs. FS7 with s709 LUT and FX9 with the LC709A LUT . Just the opposite from what Sony recommends them for. The LC709A moved the FX9 away from the green and the s709 moved the FS7 away from being magenta.
Bingo - not only did I prefer those matchups individually, but I also found that with a few tweaks I could get much better matches between them. Leaving the FS7 w/s709 LUT footage pretty much alone, I went to the FX9/LC709A combo in Resolve and cooled off the color temperature, added some magenta Tint and played with the saturation, but once I did that I had pretty damn good matches on all the colors and the face. No secondaries needed. Even the colors of charts on a vectorscope lined up way closer than before. I'm sure this would also work matching the FS7 to FX9.
Unfortunately in my tests I had to make somewhat different tweaks for different lighting conditions so its not as easy as I hoped it would be, and thus not as easy to sell to a client who might be looking for an additional FS7. However once you know the basic tricks its pretty easy. Maybe with some more tests I could come up with reliable LUTs for a client, but this stuff is very time consuming.
I’m very interested to see if anyone else has had an easier time than me or come up with other solutions. Its hard to do tests and not build in little mistakes that screw up your findings and I am aware that this sounds a little nuts :). I did hear from a friend that he just set up both cameras in Slog3 on an interview and they matched fine using the regular 709 LUT in camera (not LC709A) on presets. I’m a little suspicious, but if the angles were different enough and the shots colors happened to work you might not notice the problems. I'd be happy to hear there's an easier way.
Lenny Levy
Totally useful work and post, Lenny, since I expect mixing FS7 and FX9 footage to be pretty common around here. Thanks for sharing!
I've been trying to find a solution for the FX9 and A7iii as well. Similar issues where something would work at 5500k but be way off at 3200k. Pretty frustrating.
For multi-cam where I'm not able to apply separate LUTs, I've run both cameras in Slog3 Sgamut3.cine and applied Alister Chapman's S709 "experimental" LUT that removes the green. It's close enough that people don't notice, but it's not a perfect solution either.
Yeah that is next on my agenda . I had good luck with the FS7 for custom putting the FS7 in "f55-like and the A7iii" in "Pro". Likewise very good luck running the both the A7iii and the FS7 in SLog2 and usingthe same LUT on both - I think I used a variant of the LC709A that I made in LUTCalc for for Slog2. That was a really easy match. But the FX9 will be a different animal. Would be great if Sony would come up with an "FS7 emulation" setting for the FX9 . That should be within their abilities. It might solve the A7iii problem as well.
Did you use Alister's -G LUT on the A7iii also ? That might not be neccessary and could create problems since that camera isn't green.
You might try what I did - use the s-Cinetone LUT for the A7iii and the LC709A for the FX9. You would still have to make adjustments but who knows , its worth a shot.
I was also pretty surprised that the same solution didn't work at 5500 and 3200. I still wonder if maybe it has something to do with my testing, but i think I wore out my models graciousness.
Let us know if it works.
What would be great is if someone was able to successfully come up with an S-Cinetone-like profile for the FS7's Custom mode. That way you could get close to the FX9-look in Custom mode when shooting them together. I understand though that the FX9's color science is going to be different (better) and thus harder for the FS7 to emulate. But it would be neat if we could get close.
Speaking of S-Cinetone Lenny, where are you finding an S-Cinetone LUT?
If it makes you feel any better, we always have a hellacious time when ever we try to match F5's to our F55's in the field.
I think I downloaded it from Alister Chapman. I could probably find a link somewhere and post it here. I think if you google it Sony posted it somewhere but I'm not sure.
I know Sony (and Alister) shared a Venice LUT a while back. Is that what you’re referring to?
Yes that's s-Cinetone - at least I'm pretty sure it is.
Haha - If Its not then I just wasted a hell of a lot of time! Please let me know.
Haha, no time wasted if it got you where you wanted to go. They called that the Venice LUT, so it’s supposed to emulate the Venice. Which profile with the Venice I don’t know.
Sony website from an Alister post I believe , also Phil Bloom points here:
https://zoom.us/w/823039977?tk=PjZq...FXbkp3AA&pwd=Q09mZDMvcjJnYkkxREgwaXM0b1BBdz09
for Venice camera . I think that's supposed to be the same for FX9
Slog3-S-Gamut3.Cine To s709 V200.cube
I should probably be calling it s709 instead of s-Cinetone here. I'll go back and correct the original post .
Another minor mistake is that instead of using Sony's s709 for the FS7 (as its meant for the 15 stop Venice or FX9)
I should be using Alisters V3 venice emulation LUT which is probably a better fit for the 14 stop FS7. ( just a little more contrasty version of s709)
However the color is the same on those LUTs .
By the way these matches are still not absolutely perfect but they are pretty good.
One thing I haven't figured out is that on the vectorscope though the colors align, the FS7 reads like its much more saturated - but it doesn't look that way.
Still hoping for someone else to have a better idea.
We went through a few iterations here back in January and February when one of the companies I work with thought we'd be doing a bunch of multicam switched live feeds of two-executive chats to replace corporate meetings. (Of course as it happened all the offices closed and meetings just went to Webex... but at that point who knew?)
I had convinced them to buy a couple of FX9's - but they arrived 6 weeks apart. So first we tried two FS7's for the crossing MCU's and the FX9 for the 2-shot - a somewhat difficult match. Then the second FX9 arrived so we used the FX9's for the MCU's and an FS7 for the wide. We definitely liked the Look/Color of the FX9's with s-cinetone better for the close shots, but the FS7 match was still problematic and also felt softer.
By this time we were seeing business drop off fast, so there was no way a third FX9 was in the cards -- so as a test we tried something completely different. For the wide we replaced the FS7 with our EVA1 using one of their cine gammas and tweaking the black level and color slightly on the EVA. This ended up being remarkably close to the FX9 for everything except handling of overexposed highlights, where the FX9 seemed to hold them a little better. But otherwise an almost perfect color match and similar look, and far easier than trying to get the FS7 to look like the FX9 (or 'dumbing down' the FX9 image to try to get it to look more like the FS7). Now if we could only reduce the covid19 levels to safe we might have a workable solution when we eventually get back to work, particularly thinkng that the first jobs back may be 'social distancing multicam' feeds with no audience...
Great writeup OnSet. Awesome info. This thread has me wondering if the FS7 is having a hard time matching the FX9, how difficult will it be to get a decent match with the A7RIII/A7III type cameras? I’d love to snag an FX9 if business gets back to normal, but I use the Sony mirrorless cameras a lot for B-cams and multi-cam shoots alongside my FS7II. If matching them to the FX9 was a pain, that might deter me from going that route as the last thing I want to do is make my job harder than it needs to be.
I sent my opening post to Alister Chapman and got an enlightening (though a little but disturbing ) response:
The bottom line is they won’t match.
They use two very different sensors and the two sensors have very different colour response curves. The FS7 sensor has a slightly limited red response which is compensated for by in camera gain to some degree. The FX9 sensor has a much improved colour response with greatly extended red range and as a result less red gain. Te end result is the cameras respond to light differently and as a result they will look different even when the same LUT is used. You will find them easier to match in custom as in custom the colourspace is restricted to rec-709 so the extended range of the FX9’s sensor isn’t used and as a result both cameras are closer.
The much improved colour response of the FX9 is one of it’s big improvements over the FS7 and why it can produce a much better image, but it also means the two cameras look different and the differences will change depending on the lighting conditions.
I asked in a follow up if there was a way to "dumb down" the FX9 to fit into the smaller color response of the FS7 as he said was happening in Custom, but I haven't heard back. I'm wondering if by using the LC709A LUT I might have been doing that but frankly color space stuff gets beyond my pay grade so i'm just stabbing in the dark.
Perhaps a similar color response or color space allowed the EVA1 to match better. I am also concerned about matching with the A7iii since that is my usual 2nd angle camera. I got good matches previously in Slog2 with the FS7 and A7iii, Haven't tried with the FX9 yet.
OnSet - Thanks for the info . Other people have more experiences trying to match FX9 to FS7 or A7iii?
From my understanding the FX9 is not inherently green. The issue is that the official s709 LUT put out by Sony was created for the Sony Venice and there was no specific s709 LUT developed for the FX9. Because they're different cameras the FX9 responds slightly differently to the s709 LUT than the Venice. The FX9 looked greenish with that LUT applied. This is why Alister developed the experimental minus green LUT.
The A7iii with the minus green LUT applied doesn't look all that different from the FX9 with the same LUT. The issue I've found is the A7iii is 8 bit 4:2:0 so using SLog3 SGamut3.cine with that weak of a codec and so little color information means the image needs to be shot close to perfect in camera.
I was able to get a near perfect match on a color chart between the FX9 with Alister's s709 LUT and a custom LUT for the A7iii in SLog3 & Sgamut3.cine, but once I used my custom A7iii LUT in real life I realized I was having to stretch the colors too much and the image was breaking apart. Also, I'd shot my footage at 5500K, and when I tried to shoot in 3200K and applied the LUT it was nowhere close to usable.
Because I'd like to use these cameras in a multi-cam live streaming situation, and I'm limited by my hardware (FX9 only allows output of the MLUT, and for whatever reason doesn't make this LUT available for download) and my Shogun 7 doesn't allow outputting a LUT via the HDMI in 4xSDI mode. So I can run the Shogun 7 into a Shogun Inferno to apply a single LUT to both angles before running into the live stream. But I can't apply a different LUT to each camera.
The ideal situation, I think, is to get the cameras to natively match in non-log profiles so you can avoid LUTs altogether. At least I think that's what would work best for me.
Thanks - Interesting:
"The issue is that the official s709 LUT put out by Sony was created for the Sony Venice and there was no specific s709 LUT developed for the FX9. Because they're different cameras the FX9 responds slightly differently to the s709 LUT than the Venice. The FX9 looked greenish with that LUT applied. This is why Alister developed the experimental minus green LUT. .... The ideal situation, I think, is to get the cameras to natively match in non-log profiles so you can avoid LUTs altogether."
That fits with my experience and what Alister said about Custom. Have you tried this yet? I plan to when I get a chance and will start with FX9 in hypergamma (4,7 or 8) and matrix Std, and put the A7iii in cine4 and Pro. Just a suggestion because that sounds close to the way I ran the FS7 with A7iii.
When you say you had a near perfect match - was that just based on a visual with the color chart or looking at the vector scope. I ask because personally I've found it hard to trust either one by itself - though that may be my own inadequacy - I'm just a camera guy not a professional colorist. For me the best final test has been to gather a bunch of color photos from magazines and try to match those.
Good info guys. At guess at the end of the day it’s going to be a pain getting the FX9 to match the FS7 and Sony mirrorless line and that’s going to be frustrating and maybe even a turn off for some folks depending on their needs. However, on the flip side that also means that the FX9’s color has changed significantly over these other cameras and that’s a great thing. We just need to wait and see what other cameras they come out with (FX6, A7SIII) that have a similar color science to the FX9.
Sony would be smart to develop some kind of an emulation look as it would help sell FX9's. Don't know if they would bother with something like that though. I bought mine assuming I could make it match. Now I can't afford to sell the FS7 (assuming work comes back some day) and so have 2 great cameras, but am not eager to go out and buy a good 2nd tripod. May need to get something though maybe a chinese knock off - anyone have experience with Secced or Benro?
It took me a long, long time comparing with a vector scope to get them to match up. But then it didn't work for any other color temp and broke my image in real world use. So totally useless. But I tried! haha
