Have really no use for this anymore as I am shooting with a 5dmkII these days and need a different monitor for that camera. I used to use this monitor with my hvx-200 a lot and it worked wonderfully! Sad to see it go! The monitor is nearly in perfect condition. Screen is free of scratches and metal body has VERY VERY small nicks/surface scratches from being used. I keep my gear in pristine condition. Monitor also comes with Blue Porta Brace protective case, AC Adapter and I'll throw in the needed hvx200 component cable also!
PM or E-mail me for pictures ryan@eyerisfilms.com
Selling for $900 USD free shipping within the US! Will consider international sale.
All reasonable offers will be considered and price is negotiable.
Here's what Abel Cine says about it:
The Marshall V-R70P-HDA features a completely Digital TFT-MegapixelT high resolution LCD screen with 1.2 million pixels, V-Mount battery adapter, 4 pin XLR power jack, and optical grade polycarbonate screen protection. Analog signals are digitized using an advanced 10 bit process with 4x over sampling and adaptive 5 line comb filter plus exacting color space conversion. Video is scaled to fit on screen in the highest resolution using a state of the art LSI that incorporates 4x4 pixel interpolation with precision Gamma correction to product the best images available.
FEATURES
Durable metal enclosure
“V” Mount battery adapter included
Runs 4 to 6 hours on optional 50WH battery
High Resolution 7-inch wide screen 800x480 Dots with 1.2 million pixels
Optical grade polycarbonate screen cover with Antireflective/Antiglare coating
100% digital processing
Analog signals converted to 10 bit digital
High resolution scaling of all images
Wide viewing radius - 130° horizontal and 120° vertical provides superior visibility when the viewer is not directly in front of the screen
380 candelas per square meter (cd/m2) luminance produces enhanced image quality in varying light and viewing conditions
400:1 ratio of contrast between black and white luminance values with response rates less than 30 ms results in excellent quality for moving images
4:3 and 16:9 screen aspect ratios
Automatic NTSC/PAL format detection
Standard inputs: Composite Video PAL/NTSC with loop output, Component YPrPb HD/SD with loop out, 4 Pin XLR D.C. power jack
Easy to see three-color tally indicators
Built in Color Bars
Blue Screen for color adjustment
Adjustment Settings Memory
Includes 1/4-20 mounting plate that can be attached to any edge of the enclosure (additional mounting plates available)
Includes universal voltage Class-2 power supply
Fits into Tektronix WFM7F05/1700F05 rack adapter
Optional rack mount kit
SPECIFICATIONS
Display (Viewing Area): 7" (6.14" × 3.27")
Resolution (Pixels): 800 H × RGB × 480 V
Dot Pitch: 0.065mm × 0.175mm
Brightness (in cd/m2): 380 cd/m2
System: NTSC/PAL auto recognition
Inputs: 1 Composite, 1 Component HD/SD
Dimensions: 7.6"W × 5.16"H × 2.16"D
Approx. Weight: 1.8 lbs
Power Consumption: 10-17 VDC, 600 mA
FEATURES
Built in Color Bars
SPECIFICATIONS
