SOLD Marshall V-LCD561STX-3GSDI-VM Monitor
Status
Not open for further replies.
virtuoso
Up for sale is a slightly used but 100% functioning Marshall super transflective monitor with the 3GSDI upgrade and a V-Mount plate. I would write my own description, but the one from B&H sums it up the best so you can read theirs below. I'm selling this because I work in a studio now and all of my equipment is supplied by the production company, and when I do freelance jobs, I end up using my other monitor that has HDMI inputs since I shoot on mostly DSLR cameras.
This monitor goes for $1884.85 new and I am looking to sell mine for $999.00!
Payment via PayPal only. Free shipping to DVXuser members! Sorry, continental U.S. sales only!
This is also available for sale on eBay under username virtuosovending if you want to see that I'm safe and legit.
Here's the specs:
Super Transflective
Designed specifically for outdoor applications with high ambient light, Marshall's outdoor super-transmissive LCDs provide improved visibility by producing high-contrast images and a wider viewing angle, even under diverse and challenging lighting environments. This innovative technology dramatically boosts the efficiency of the LCD backlight's light utilization, while maintaining extended temperature ratings and low power consumption for outdoor operation.
False Colors
The False Color filter is used to aid in the setting of camera exposure. As the camera iris is adjusted, elements of the image will change color based on the luminance or brightness values. This enables proper exposure to be achieved without the use of costly, complicated external test equipment.
Peaking Filter
The Peaking Filter is used to aid the camera operator in obtaining the sharpest possible picture. When activated, all color will be removed from the display and a black-and-white image will remain. The internal processor will display RED color on the screen where sharp edges appear. When the camera operator adjusts (or "racks") the focus, different parts of the image will have RED colored edges. This indicates that this portion of the image is sharp or in focus.
Battery Compatibility
These units offer the ability to adapt up to nine different battery configurations for providing mobile operation in the field. This option provides flexibility when using different cameras or configurations. Marshall's large selection of battery adapters can be interchanged (or "swapped out") by the end-user.
Scratch Resistant Screen
As almost all professionals know, the field can often be a rough place. The LCD is built from the ground up to weather the storm. By incorporating a scratch-resistant panel, users no longer have to worry about that occasional branch making contact with the monitor.
Why Choose Marshall vs. Cheaper Monitors?
  • Durable, thin, and lightweight construction
  • 650 cd/m² brightness, 500:1 contrast ratio
  • 4 user-configurable function buttons
  • RGB gain and bias control
  • User-adjustable panning (Pixel-to-Pixel mode)
  • Signal integrity meter
  • Optional Heavy-Duty Protective Shield
  • RGB Check Field / Field Detect
  • 16:9, 4:3, Pixel-to-Pixel modes
  • Variety of markers
  • Freeze frame
  • Active input loop-through/reclocked output
  • Robust 12V 4-pin XLR power connector
  • Designed, engineered, and assembled in USA
Status
