[FS: General] Marshall Electronics V-LCD70XP-3GSDI 7" LCD Field Monitor
gorannera
Marshall Electronics V-LCD70XP-3GSDI-AB 7" LCD Field Monitor with Anton Bauer "Gold Mount" Plate Price: $499
Lightly used for a short period of time. Near new condition having few signs of cosmetic wear. In perfect working condition and completely operational. This is the SDI model and signal can be passed through to a larger monitor. Images are of actual items you will receive. The velcro tape attached on the two corners of monitor. Power Supply V-PS12-5V-XLR not included.
Items Included:
Marshall Electronics V-LCD70XP-3GSDI-AB 7" Field / LCD Monitor (Anton Bauer Mount)
Serial number available on request.
Monitor offers false color, pixel to pixel focusing, peaking filter / focus assist, freeze frame, adjustable markers and more. Also offers loop-through output so you can connect to a larger monitor as well.
Price: $499
Goran Nera
DP / Camera Operator
Los Angeles
Along with its Anton Bauer "Gold Mount" and component/composite inputs, the V-LCD70XP-3GSDI-AB comes equipped with 3G/HD/SDI input -- output for uncompressed 1080p compatibility. The signal can be routed thru the monitor to another device. Plus a variety of screen formats, markers and user-configurable function buttons.
Marshall's Professional Details
Marshall Electronics builds their LCDs for professional applications and convenient, user-friendly operation. In addition to its high quality image, the display will accept a wide variety of input signals. Variety of User-Replaceable Battery Adapters available*. (e.g. Sony, Canon,Panasonic, etc)
Completely Digital
The V-LCD-70XP-3GSDI-AB features a completely digital TFT high resolution LCD screen with 1.2 million pixels, 4-pin XLR power jack, and optical grade polycarbonate screen protection. Analog signals are digitized using advanced 10-bit processing with 4x oversampling and an adaptive 5-line comb filter.
Automatic NTSC/PAL Recognition
The V-LCD70XP-3GSDI-SB accepts both NTSC and PAL standard signals. Conveniently, the monitor automatically detects which standard it is being fed without having to push a button, flip a switch or access a menu option.
False Color & Peaking Filters
A sophisticated color and peaking filter system will let you run tests and do various adjustments in order to achieve very accurate color and sharpness settings according to a particular lighting and scene situation. Once these settings are locked in, you can be sure that what you see on the monitor is exactly what the camera is capturing.
False Color Filter
The False Color filter is used to aid in the setting of camera exposure. As the camera Iris is adjusted, elements of the image will change color based on the luminance or brightness values. This enables proper exposure to be achieved without the use of costly, complicated external test equipment.
Peaking Filter
The Peaking Filter is used to aid the camera operator in obtaining the sharpest possible picture. When activated, all color will be removed from the display and a black-and-white image will remain. The internal processor will display RED color on the screen where sharp edges appear.
Scratch Resistant Screen
As almost all professionals know, the field can be a rough place. The monitor's LCD incorporates a scratch-resistant protective screen, so you no longer have to worry about a stray branch leaving its mark across your picture-perfect image.
15:9, 16:9, 4:3, pixel-to-pixel modes
RGB gain and bias control
SPECIFICATIONS
Application:
Field Monitor
LCD Size:
7"
Video System:
NTSC, PAL
Picture Elements:
800 x 480, 18-Bit Color
Input and Output Connectors
Composite Video: BNC (x1 Input, x1 Output)
Component Video: BNC (x1 Input, x1 Output)
3G/HD/SDI: BNC (x1 Input, x1 Output)
Picture Controls
Brightness, Color, Tint, Contrast, Menu, F1-F4
Remote Control
No
Power Requirements
Battery
12VDC
Power Supply (XLR)
100-240VAC, 50/60Hz
Power Consumption
12W
Dimensions (WxHxD)
7.03 x 5.7 x 2.17 (17.9 x 14.5 x 5.5 cm)
