True North
OVERVIEW AND SUMMARY
- I bought this monitor 10 months ago.
- After a lot of research, I chose this monitor because relatively speaking it offered the most in terms of price, size and functionality
- I would estimate that it has seen about 30-40 hours of use in the field...in other words it has barely been used
- I love this monitor but it is much more than I need and I want to get other peices of gear.
- As the pictures will dictate, the item is in excellent, like new condition
- I have two battery plates ($30/plate) that come with this unit; (1) Panasonic CGA-D54 Plate (2) Sony Plate
- Pictured separately is the 3G SDI connection plate. It is currently not connected because I wasn't using it and just wanted to remove it in case I accidentally damaged it while transporting.
- It is very easy to reattach (couple of screws and a ribbon cable attachment)
The total package retails for around $1600 new - http://www.bhphotovideo.com/c/produ...V_LCD90MD_3G_V_LCD90MD_3G_9_HDMI_Monitor.html
- If you happen to live in or be in the Greater Toronto Area I will make local pick up available.
- Free Shipping DOES NOT include insurance but can be added at an additional cost
- I will accept payment by Paypal, Bank Transfer or Money Order
- I will also accept cash but no cheques of any kind for local pickup.
- I will only ship to Paypal verified accounts
The unit will be safely and securely packaged/shipped.
[TABLE="width: 100%"]
[TR]
[TD="align: center"][/TD]
[/TR]
[/TABLE]
Here are some of the highlights taken from the Marshall website http://www.marshallmonitors.com/products/monitors/V-LCD90MD/index.html ;
PHOTOS ARE IN THE POSTS BELOW THIS ONE
Your Price is
$1170
with FREE shipping (USA and Canada see below)
- Price includes shipping to anywhere in the USA (except Hawaii and Alaska where a discounted shipping rate will be used) and Canada (except Nunavut and NWT where a discounted shipping rate will be used).$1170
[TR]
[/TR]
[/TABLE]
- High Resolution 1280 x 768 White LED Backlit IPS panel
- High Brightness 600-nit with Adjustable Backlight
- Available in three Configurations:
- V-LCD90MD (No Module)
- V-LCD90MD-O**
(3G Output Module with two 3G-HDSDI outputs converted from the HDMI input. HDCP Compliant) - V-LCD90MD-3G (3G Input Module with loop-through)
- DSLR Ratio Adjustment with 4 DSLR Ratio Presets
- On Screen Waveform / Stereo Audio Bar Display
- Manual Gamma Adjustment
- Adjustable IRE Clip Guide (Zebra Filter)
- 1/4"-20 mounts on all sides
- Stereo Headphone Output (select a L+R Pair from the available channels)
- 6 Monitor Configuration User Presets
- Custom Screen Markers (choice of four colors and variable lines widths)
- HDMI Pass-Through (HDCP Compliant)
- HDMI Auto Color Space and Ratio detect
- New Peaking Filter (Choice of four color highlights and variable sensitivity)
- False Color Filter
- Four User Assigned Function Buttons with 32 possible uses
- Pixel-to-Pixel Panning (Custom Pixel-to-Pixel Mode)
- 15:9, 16:9, 4:3, Pixel-to-Pixel modes
- Input Crop with automatic scaling
- RGB Check Field with Monochrome
- Scratch Resistant Protective Screen
- Variety of Optional User-Replaceable Battery Adapters available
- Icon assisted Menu System
