I'm selling my Marshall V-R70P-HDSDI 7” Widescreen HD LCD Monitor w/ HD-SDI in pristine condition.
I've only used it a handful of times and it has always been used with a protective cover and stored in a pelican case.
Asking $975 and it was purchased for $1700.
Call me with any questions!
(801)787-3182
James Allred
Here it is on AbelCine: http://www.abelcine.com/store/7-Marshall-V-R70P-HDSDI-Widescreen-HD-LCD-Monitor-w-HD-SDI/
FEATURES
Durable metal enclosure
Runs 4 to 6 hours on optional 50WH battery
High Resolution 7-inch wide screen 800x480 Dots with 1.2 million pixels
Optical grade polycarbonate screen cover with Antireflective/Antiglare coating
100% digital processing
Analog signals converted to 10 bit digital
High resolution scaling of all images
Wide viewing radius - 130° horizontal and 120° vertical provides superior visibility when the viewer is not directly in front of the screen
380 candelas per square meter (cd/m2) luminance produces enhanced image quality in varying light and viewing conditions
400:1 ratio of contrast between black and white luminance values with response rates less than 30 ms results in excellent quality for moving images
4:3 and 16:9 screen aspect ratios
Automatic NTSC/PAL format detection
Standard inputs: HDSDI/SDI (Smpte-292M/259M), 4 Pin XLR D.C. power jack
Easy to see three-color tally indicators
Built in Color Bars
Blue Screen for color adjustment
Adjustment Settings Memory
Includes 1/4-20 mounting plate that can be attached to any edge of the enclosure (additional mounting plates available)
Includes universal voltage Class-2 power supply
Fits into Tektronix WFM7F05/1700F05 rack adapter
Optional rack mount kit
SPECIFICATIONS
Display (Viewing Area): 7" (6.14" × 3.27")
Resolution (Pixels): 800 H × RGB × 480 V
Dot Pitch: 0.065mm × 0.175mm
Brightness (in cd/m2): 380 cd/m2
System: NTSC/PAL auto recognition
Inputs: 1 HDSDI/SDI
Dimensions: 7.6"W × 5.16"H × 2.16"D
Approx. Weight: 1.8 lbs
Power Consumption: 10-17 VDC, 600 mA
(801)787-3182
James Allred
FEATURES
Built in Color Bars
SPECIFICATIONS
Inputs: 1 HDSDI/SDI
