This is a "KIT" version of the Marshall Electronics V-LCD5.6-Pro is a full featured LCD display with a built-in speaker and reverse image capability. With the field battery, and Hoodman sun shade, the street value of this package is over $350.00.
This is a VERY very low-use LCD video monitor which has seen only about 40 hours of use. There is not usage wear except a slight abrasion ring under the monitor from the hot shoe adaptor. This is also the "Kit" version, including with both AC and a DC (2hr) field battery, as well as a Hoodman sun shade and case.
The V-LCD 5.6-Pro will work adequately with shoulder mount broadcast style cameras or even smaller cameras and DSLRs (we used it on a Panasonic AG-HVX100). It is equipped with sound, color, contrast and brightness controls. This monitor also has an earphone plug for private sound monitoring.
The 5.6-inch LCD panel quality is high enough to use not just for framing and confidence but for location or impromptu playback, where a larger monitor is impractical or absent. Small enough to mount on top of even the smallest video cameras, the comprehensive list of features give it utility in a variety of scenarios. The built-in speaker simply adds to its versatility.
This is the kit version and includes a rechargeable battery pack and a handsome nylon carrying case with shoulder strap. The carrying case is designed to hold all the necessary battery pack and cables ready for field use. The rechargeable battery pack will power the unit for 2 hours continuously. This kit also includes a wall adapter allowing the unit to be used while the battery is being charged. This kit comes complete with built-in tilt stand, AC power supply, field battery adapter cables, carrying case and a Hoodman sun shade.
Reverse Image Feature
When RV or bus drivers employ a video camera on the back of their rig, the V-LCD5.6-PRO can flip the image to display like a rear view mirror.
Extras Include:
• Hoodman H600 LCD Sunshade
• 2-hour battery and charger
• Carrying Case (holds all components except AC adaptor)
LCD Monitor Applications - Portable, Camera Mountable
• Display (Viewing Area) 5.6" (4.57"H × 3.43"V)
• Resolution (Pixels) 960H × 234V
• Dot Pitch 0.116mm × 0.348mm
• Brightness (in cd/m²) 250 cd/m²
• Plastic cabinet with 1/4" mount
• Power supply and adapter cables included
• Side mounted volume, color, contrast and brightness controls
• Built-in speaker
• Video System - NTSC
• Input and Output Connectors - Composite Video- RCA (x 1 input only)
• Audio- RCA (x 1 input only) - Headphone- Mono Mini (x 1)
Remote Control - None
Camera Mount - 1/4 inch female
Power Requirements - Both AC and 12 Volts DC
Power Consumption - 600 mA
Dimensions (WxHxD) - 6.4 x 5.3 x 2.0 inches
Weight - 1.14 lbs.
Contact: Dorian 503.484.7713 <iamdorian@mac.com>
Extras Include:
• Built-in speaker
Weight - 1.14 lbs.
