Barry_Green
Moderator
This is a guy who gets it. And it shows.
Sample quotes:
This applies to filmmaking just as much as it applies to anyone else. I've met so many who are so passionate about their 'dream' to be a filmmaker... but they suck. It's sad. They waste so much of their life chasing after something that they will never, ever, ever catch, instead of excelling at what they could be excellent at.
So what should you be doing instead? According to Cuban:
I've lived what he's talking about, and I can tell you -- he's spot on.
Another way of saying what he's saying -- writers write. That's all they do, because that's all they want to do, that's all they can do, that's all they will do... they can't not write. They don't "want to write", they don't dream about someday writing, they write and they write and they write and they write and they write. If that's not you, then guess what -- you're not a writer. It doesn't matter how much you "want" to be a writer... it doesn't matter how much you dream about it, or how passionate you are about it. It matters how much you do it. And the more you do it, the better you'll get at it, and, as Cuban said, it'll snowball.
And if this isn't you? If you suddenly realize you're in the wrong field? What now? Cry and moan because you're frustrated, or you've failed, or you've wasted your time? Of course not! Now is the time to celebrate, because finally the shackles are off, you can quit being what you're not, and you can now devote effort to being what you are.
Sample quotes:
"Everybody tells you, 'Follow your passion, follow your passion.'"
Cuban says that's bad advice because you may not excel at what you are passionate about.
"I used to be passionate to be a baseball player. Then I realized I had a 70-mile-per-hour fastball," says Cuban. Competitive major league pitchers throw fastballs in the range of 90-plus miles per hour.
"I used to be passionate about being a professional basketball player. Then I realized I had a 7-inch vertical," says Cuban. Top contenders for the NBA draft in 2017 each had a max vertical leap over 40 inches.
"The things I ended up being really good at were the things I found myself putting effort into. A lot of people talk about passion, but that's really not what you need to focus on. You really need to evaluate and say, 'Okay, where am I putting in my time?'" says Cuban.
"Because when you look at where you put in your time, where you put in your effort, that tends to be the things that you are good at. And if you put in enough time, you tend to get really good at it," explains Cuban.
When you are good at something, you enjoy it, says Cuban. The effort and skill snowball.
"If you put in enough time, and you get really good, I will give you a little secret: Nobody quits anything they are good at because it is fun to be good. It is fun to be one of the best," says Cuban.
"But in order to be one of the best, you have to put in effort. So don't follow your passions, follow your effort," says Cuban.
"I am going to give you one other secret: The one thing in life that you can control is your effort," says Cuban.
