I was trying out the DVX100a, before I had read the manual completely, and figured I wouldn't do any harm. But I found out that I shouldn't have fooled with the manual zoom ring with the camera set to Servo mode, which was the factory setting, or there may be malfunctioning -- at the time, I didn't know you had to switch between the two; I only found out after I had begun reading the manual. Could this have caused any damage to the 100a? Everything seems to be fine, except that the zoom ring is very sensitive, and "silky" in its turning, meaning that it is easilly moved. I notice that I prefer the zoom rings feel when the camera is set to Servo mode, but of course, using it this way may cause even more damage. Zooming manually is a little hard to accomplish smoothly, without it looking jerky. Is it because I may have damaged the ring or zoom function, that causes it to be so sensitive, or is the ring always this way? If so, how can I maintain a good and steady zoom, especially slow zooms?
