GH5 Manual focus problem. help!
FoxAdriano
Hi, maybe I clumsily touched some wrong key or something in the Menu in my GH5. Before I had the right screening on the viewfinder. If I wanted a manual focus, at the moment I turned the Leica lens ring I saw an enlarged rectangle in the center of the screen. Now I don't see that enlarged rectangle anymore but all the image gets bigger.
How can I restore than option please?
Go to the main menu
Scroll down on the left side to the c/spanner icon
Select the focus icon
Go to page 3 of 6, second function "MF Assist Display"
Change between Full or PIP
You're great. I thank you a lot. I have also another question please. I attach you a screen tapping fn5. On that screen I always see abled "Conv.Tele est." (it is in my language) and I always see film on "OFF". Why please? I have always to disable "Conv.Tele est."manually in the Menu and then I have to put Film on "ON" in that screen. Why please? I have GH5 from a little time and the the manual isn't translated fine in my own lnguage.
https://www.dropbox.com/s/44zcmoiutner5y2/IMG_20180326_174731.jpg?dl=0
Thanks again one.
Thanks again one.
I'm not sure I completely understand the question.
But I will give you my workaround for engaging tele. I have custom assigned the opening of that page to a physical button, in my case the button that sits on the front of the camera to the side of the lens mount. Pressing that button brings up the tele-convert page. I then use the joystick on the back of the camera to toggle between on and off.
There might be more elegant ways of doing this like perhaps assigning two identical camera settings aside from this function, and saving those settings to two of the custom settings on the top mode dial.
I wish Panasonic had made it a simple button push to engage tele based on how the mode dial was set, but for now I'll live with the extra button pushes I have to make without having to go into the menus.
In fact you don't understand my bad english. ;) I'm sorry. Now I explain you with other words.
1) If you make video and you open that screen I attached you in my previous post, you see "Film: ON" or "FILM: OFF"?
2) I always see "FILM: OFF" and if I click on "Film: ON", "Con.Tele Ex." is activated automatically but I DON?T WANT to enable it.
I hope I am clearer now.
I thank you.
I thank you.
So if I understand you, you do not want to use the ex tele-convert function, correct?
If that is the case then do not turn the function on. Leave it off. Do not click anything.
Adriano, la schermata ti chiede se vuoi attivare l'estensione tele digitale in modalità Film o Foto. Se non la vuoi usare (si usa raramente, infatti) devi lasciarla OFF.
