Up for sale is my Manhattan LCD HD089B screen. I used this for 3 days when I shot my short for quest fest. I have sold my adaptor and most my gear so I really can't use it right now. It works flawlessly and includes all of the original accessories. I have sold several high dollar items here including my GH1. Specs are listed below. SOLD
This monitor has The more advanced Pixelworks chipset it has features such as an advanced color Control, true anamorphic 16:9 aspect ratio, 1:1 Pixel Mapping & is also firmware upgradable.
Chipset: Upgraded Pixelworks PW338
Inputs: HDMI, Component, Composite & VGA
Supported resolutions: 480i, 480p, 576p, 720p, 1080i & 1080p
Compatibility: NTSC & PAL
Supported aspect ratios: 4:3 & 16:9
LCD native resolution: 1024 x 600
Contrast ratio: 500:1
Brightness: 300 nits
LCD Finish: Antiglare
RGB Adjust: Yes (in hidden menu)
Mounts: 2 - 1/4x20 Bottom, & Top (for flip)
Case material: ABS Plastic
Weight: 1.8 lbs
Input Voltage: 12V DC 2A
Power connector: 5.5mm X 2.1mm barrel connector
Flip feature: Manual
HDCP Compliant: YES
1:1pixel mapping: YES
Under Scan: NO
Blue Only: NO (use blue gel method for calibration)
HDSDI: NO
Remote Control: YES IR
Weight: 1.8 lbs
HDCP Compliant: YES
Under Scan: NO
HDSDI: NO
