Manhattan LCD 089A Complete Mint & Callibrated!
Zephyrnoid
Model # HD089A
Condition: Mint in Box.
$440 + shipping to CONUS . It goes to EBay in November if not sold here.:violin:
8.9" (diagonal) HD Professional LCD Monitor
This is the least expensive MST controller based LCD monitors. Designed for field monitoring these wide screen LCD monitors are full HD compatible. Works with most model prosumer HD video cameras. Pre-Callibrated to NTSC HD Spec with my Matrox MX02 using Blue Gun . You can reset to factory default and calibrated it yourself any time.
Chipset: Base Model MST
Inputs: HDMI, Component, Composite, S-video, TV tuner & VGA
Supported resolutions: 480i, 480p, 576p, 720p, 1080i & 1080p
Compatibility: NTSC & PAL
Supported aspect ratios: 4:3 & 16:9
LCD native resolution: 1024 x 600
Contrast ratio: 500:1
Brightness: 300 nits
LCD Finish: Antiglare
RGB Adjust: Yes (in hidden menu)
Mounts: 3 - 1/4x20 Bottom, Left & right sides
Case material: ABS Plastic
Weight: 1.8 lbs
Sun hood: Optional
Battery - Not included. Tekkeon is Recommended
Input Voltage: 12V DC 2A
Power connector: 5.5mm X 2.1mm barrel connector
Flip feature: Manual
HDCP Compliant: YES
1:1pixel mapping: NO
Under Scan: NO
Blue Only: NO (use blue gel method for calibration) - Not required for this unit.
HDSDI: NO
Remote Control: YES IR
Warranty: Standard 1 Year Manhattan LCD.
Includes User Manual
