Manfrotto Superclamp
muroshi
Unfortunately they don't come with a spigot. Which one do I have to get for mounting a dedolight?
It depends on what the dedolight connector is. If it's a standard 5/8 ("baby", like a c-stand arm or pin) there's one made that's a simple 5/8 post. I have a couple older 2" fresnels with 1/4" mounts, no superclamp stud for that, you'd need a 5/8 to 1/4 post adapter (not threaded). If it has a female threaded scket (like some consumer gear or hotshoe mount stuff) of 1/4-20 or 5/8-16, there are studs that have male threaded posts.
it has a standard 5/8 receiver. also a 1/4 inch threaded mount
just get some 5/8 rod in steel or aluminum and hacksaw it to desired length
you can then make as many as you need
the dedo is compatable with any 5/8 fitting
I have Manfrotto snap-in pins for those clamps and 1/4"-20M to 3" baby pins. PM me if you need them.
e
No, this one... the Manfrotto-Avenger E600 (less than $9).
attachment.php
