[FS: General] Manfrotto 561BHDV Fluid Video Monopod w/Head - $200 (L.A. Area Only)
vcassel
Manfrotto's 561BHDV Fluid Video Monopod W/Head will take you somewhere you might never have been: more than 6 feet off the ground with a monopod. The maximum height of 6.56' (200 cm), minimum height of 2.5' (76.5 cm), and included compact, lightweight fluid head of this 4-section aluminum monopod give you versatility to spare. The head has a long sliding plate, and the ergonomic pan-bar provides smooth panning and tilting. Three mini supports at the base bring added stability. This monopod and head were designed specifically for light prosumer and professional compact HD camcorders plus lightweight spotting scopes (up to 8.8 lbs).
• The ergonomic pan-bar allows smooth panning and tilting movements
• Maximum height of 6.56' (200 cm)
• Minimum height of 2.5' (76.5 cm)
• The small, compact and lightweight fluid head was developed and designed to specifically to support the latest light prosumer and professional compact HD camcorders plus lightweight spotting scopes up to 8.8 lbs
• Updated controls on the fluid head allow a more solid grip and better fluidity, plus improved performance and ergonomics
• The fluid head's improved internal fluid cartridges, a pan-bar rosette and a bigger sliding plate optimize the position of the camera or spotting scope, relative to its center of gravity.
Comes with...
The Manfrotto 361 Shoulder Brace for Monopods is a bracket that fits against the shoulder to provide extra support and greater stability to a monopod. One end connects to the top of the monopod via the monopod's 3/8" screw, and the other end features a curved shoulder support, with an adjustable pivoting arm in between.
The monopod sells new for $270 and the shoulder brace sells new for $24.95. I'm selling them together for $200 like new. Cash/local L.A. area only. Not interested in trying to ship this.
View attachment 29210View attachment 29211
