[FS: General] Manfrotto 503HDV Pro Fluid Video Head 503 HDV with Quick release plate 501PL
Status
Not open for further replies.
tokun1
PLEASE SEE OUR EBAY LISTING FOR THIS ITEM - CLICK HERE!
MANFROTTO 503HDV PRO FLUID TRIPOD HEAD WITH HANDLE AND QUICK RELEASE PLATE
I purchased this head brand new 2.5 years ago from BHphoto.com. It is used, but when not in use it was always stored in a tripod back in the closet, I take extremely great care of all of my production gear as you can see it almost looks brand new in the photos and is extremely clean and works perfectly.
*Note: There are a few small scratches on top part of the tripod handle as shown in the photos, this can be easily touched up with some black touch up paint, I never got around to touching it up. I upgraded to the 504HD head and got a new tripod so that is why I'm selling this 503HDV head here on Ebay.
Information as listed at BHphoto.com:
Being very much aware of changing trends in the video world, Manfrotto revised their proven 503 fluid head taking into account the increasing performance demands of High Definition Mini-DV camcorders. The result is the 503HDV Pro.With regard to ergonomics, the engineers at Manfrotto designed the 503HDV with entirely left-handed controls to enhance operational efficiency. Since camera controls are generally left-handed, every setting may be inspected and verified at a glance, facilitating rapid setups from shot to shot.The greater resolution of High Definition video means that details as well as errors in movement are more apparent, and thereby demands a more refined means of support. The continuously-variable fluid drag system of the 503HDV provides just the right amount of dampening for any shot on your list-from whip pans to slow motion, just dial in drag to touch. This capability in conjunction with the 3-step counterbalance delivers the type of fingertip camera control normally reserved for much more costly production fluid heads. ENG crews and independent filmmakers alike will appreciate the thoughtful, full-featured design of the 503HDV fluid head as it expands their shooting gamut without unnecessarily shrinking their budgets. As with all other Bogen/Manfrotto supports, it includes a two-year warranty and comprehensive online documentation.
Continuously-variable fluid drag
Multi-spring 3 step counterbalance
Sliding balance plate with 58mm of travel
Replaceable dual pan arm rosettes
Illuminated bubble level Specs:
[TABLE="class: specTable"]
[TR]
[TD="class: specTopic"]Load Capacity [/TD]
[TD="class: specDetail"] 17.6 lbs (8.0kg) [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Diameter/Thread [/TD]
[TD="class: specDetail"] 3/8-16 [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Counter Balance System [/TD]
[TD="class: specDetail"] 3-step [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Counter Balance Range [/TD]
[TD="class: specDetail"] 0 - 8.8 lbs (0 - 4kg) [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Center of Gravity [/TD]
[TD="class: specDetail"] Not Specified by Manufacturer [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Quick Release/Wedge Plate [/TD]
[TD="class: specDetail"] Yes, with 1/4-20 and 3/8-16 mounting screws [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Balance Plate [/TD]
[TD="class: specDetail"] Yes, with 58mm of travel [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Tilt Drag [/TD]
[TD="class: specDetail"] Continuously variable [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Tilt Range [/TD]
[TD="class: specDetail"] -60° to +90° [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Tilt Lock [/TD]
[TD="class: specDetail"] Independent [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Spring Loaded Counter Bal [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Pan Range [/TD]
[TD="class: specDetail"] 360° [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Pan Lock [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Leveling Bubble/Illuminated [/TD]
[TD="class: specDetail"] Yes/Yes [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Temperature Range [/TD]
[TD="class: specDetail"] -4°F to 140°F (-20°C to 60°C) [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Height [/TD]
[TD="class: specDetail"] 4.5" (11.5cm) [/TD]
[/TR]
[TR]
[TD="class: specTopic"]Weight [/TD]
[TD="class: specDetail"] 4.4 lbs (2kg) [/TD]
[/TR]
[/TABLE]
Status
