[FS: General] Manfrotto 501 + 525MVB + QR Plat + Bag - GREAT OFFER !!
aurson
Carbonite Member
Full tripod included: Manfrotto 501 + 525MVB + QR Plat + Bag
DESCRIPTION
*** Manfrotto 501 + QR Plate ***
It's used but in VERY GOOD CONDITION.
It features improved drag on both axes and switchable counterbalance for the latest ultralight high-definition camcorders. Controls have superior operational ergonomics.
Specifications:
Load Capacity - 13.2 lbs (6.0 kg)
Diameter/Thread - 3/8"-16
Counter Balance System - Fixed spring
Counter Balance Range - Optimized for 5.5 lbs (2.5 kg)
Quick Release/Wedge Plate - Yes (501PL)
Balance Plate - Yes, with 58mm of travel
Tilt Drag - 1-Step
Tilt Range - -60 to +90°
Tilt Lock - Separate
Pan Drag - 1-Step
Pan Range - 360°
Pan Lock - Separate
Leveling Bubble/Illuminated - Yes/Non
Temperature Range - 14 - 140°F (-10 - 60°C)
Height - 4.5" (11.5 cm)
Weight - 3.5 lbs (1.6 kg)
*** Manfrotto 525MVB ***
Made of lightweight high-tensile aluminum. This three-section easy-to-handle tripod has two-stages, operating from a low 12.5" to over 5 ft.
Specifications:
Material - Aluminum
Load Capacity - 33.1 lbs
Bowl Diameter/Thread - 75mm 3" Half Bowl
Minimum Height - 12.5"
Maximum Height - 61.5"
Leg Stages/Sections - 2/3
Leg Lock Type - Fast Action Locks
Center Brace/Mid-Level Spreader - Ground Spreader (included)
Spiked/Retractable Feet - Spiked
Folded/Transport Length - 28.0"
Weight - 7.5 lbs
*** Manfrotto tripod bag ***
It's used but in GOOD CONDITION, except fora broken zipper in one of the sides.
***** I'm selling it in ebay (I accept offers)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220692397929
Aurson if you want you could call me and I can ask more questions and may be we could make a deal on some of your items.
Phone 1 519 256 1997
Peter
Hello Peter,
The tripod is about 2 years old. Its weight (as described in my first post) is about 11lbs (5Kg approx.). If you have more questions or you want to make me any offer for the items I'm selling, PM me and I will try to answer all of your questions.
Regards
