ullanta said:Slice the throat of a pure white llama, spill the blood on the ground
Chant repeatedly: "Paramuriway sumaq phuyu! Paramurqoriway janaq pachamanta!"
pachamanta!"
webdog said:I did it once using a hose and a 10ft pvc pipe with wholes drilled every inch... looked real just dont drill all your woles in the same spot on the pipe that way water will go all over and look more real.
not really, i used real small drill bits and varied the size so it made it less uniform making it more real.dougspice said:Doing that, wouldn't you lose pressure the further you got from the hose? Did the water at the far end of the tube come out a lot thinner than at the close end?
