Macbook Pro for converting Raw 4k?
m3rob
Does anyone use a Macbook Pro to convert 4k Raw CDNG files recorded with the odyssey 7Q on location? If so, using Davinci Resolve, how many frames per second in the render would you get you would get converting the 4k Raw to an editable 2k or 1080 prores? I get about 19 frames per second with my 2009 mac pro. Its too big to bring to most jobs. My brother has a newer macbook Air, but it only converts 2-3 frames per second. I was hoping the Macbook Pro is in the 10-15 frames per second range?
Anyone have any results to share? Also if you could list your model and which graphics card it is using on the macbook pro that would be great!
Thanks!
Rob
I have a quite new i7 / 16GB RAM / 2GB GTX750 MBP.
With only camera RAW adjustments no further nodes I have at full decode quality ony 5fps.
At half resolution it's 18-20fps in a 1080 timeline. hth
question....why do you need to transcode on set? Like, what's your workflow? Maybe there is a different solution to your need...
I didn't need to transcode on set after all. I had the chance to bring it home to convert all the Raw 4k Slow motion footage and to do a basic color correct on all the 4k Prores S-log material I recorded before I handed it off. I was just wondering if a Macbook Pro was fast at converting, but I tried a computer similar to Clermond's yesterday and I too got only 5 fps.
