BobDiaz
The Professor
I'm currently running a 20" 2.4 GHz Dual Core iMAC with 2 GB of 667 MHz DDR2 SDRAM.
By right clicking on the HMC-150 .MTS files on my Hard Drive I can select the Toast Video Player and play back the .MTS file in real time.
720/24p PH Mode, No Problems
720/30p PH Mode, Plays the 30p at 2x speed and stops when it reaches the end of the video. The audio is playing back at normal speed.
720/60p PH Mode, No Problems
1080/24p PH Mode, No Problems
1080/30p PH Mode, No Problems
1080/60i PH Mode, Can play back at 29.97 up to a point, then it drops to 24 - 26 FPS (varies), but otherwise plays back OK.
1080/60i HA, HG, HE Modes, Plays back without any problems.
Clips used, Barry Green's rain clips.
Note: Pressing OPTION+COMMAND+I while the clip is displayed, will bring up or remove the information on the clip. Interesting to watch during playback to see the bit rate change.
So, for those with other MACs and Toast 9, I'd be interested in seeing how well your MAC does with real time playback of the clips. Please try it and post your results....
I'm going to try a few other tests and I'll post the results when I'm done...
Bob Diaz
Bob Diaz
