Mac specs for HD?
C Walker
I'm planning on some HD goods be years' end, but what internals should I have at a minimum? I know the processors will be fine, but what about RAM? 4GB, 8GB, 10, 12? Graphics card OK? ANything else I need to know? Capture card?
Currently:
Mac Pro
2x2.8GHz Quad-core Xeon
2 GB 800MHz DDR2
NVIDIA GeForce 8800 GT
i'm either getting an HPX-170 or HMC-150.
:dankk2:
Looks like your system will be fine with the RAM exception.
Go for as much as you can afford. But I'd say a minimum of 12GB RAM.
As far as I know that graphics card should be good. Unless you want to splurge on a ATI 4870. But I don't think it's needed.
For AVCHD or DVCPROHD work I'd say 12GB is way overkill. I've worked with 4 GB or even 3 for years in those formats and been fine. But then again if you can afford it, get more RAM- at least up to 4 or 6 and then spend the rest on fast hard drive space. Never have too much of that.
Noah
Yeah those would be good too- especially for high-end color correction properly. What you see on the desktop is not what you're really getting back on a broadcast monitor.
Noah
The 8800GT is a bit gimpy w/the ProApps compared to Apple's ATi offerings. Even the lower-spec'ed ATi x1900xt out performs the 800GT when it comes to Color and Motion.
-A
Noah
any suggestions in this area? should i be looking at something like a Matrox as well?
Okay, after researching this, i'm more confused. Matrox or Blackmagic? What to use as a preview monitor? ugh...
Go to macsales.com. They have a video on upgrading ram and some interesting test results on the best amounts and where to put them.
