Mac Pro Vs Macbook Pro and other questions
This forum rules. *I just want to get that out of the way up front.
I've learned so much about my GH-1 from this site that I feel like
I've read a textbook on it.
I'm at the earliest stages of preproduction on a short that I'll shoot
with my GH-1, but I want to get my editing system in order (and budget
properly) before I go forward with production. *I decided to go the
FCP route mainly because of my positive experience with Final Cut
Express. *Unfortunately, right now I'm slogging along with a Macbook,
and and so I'm going to have to upgrade. *This is a question that's
been asked before, but:
Should I get a Mac Pro, or will a MacBook Pro suffice?
I found this article elsewhere on the forum, but it's a little stale,
and I was hoping to get the opinions of some GH-1 filmmakers.
http://www.dvxuser.com/V6/showthread.php?t=68844
Specifics on my shoot:
1. *Portability is not a priority, as I'll be editing after the shoot
2. *The short will be 10-15 minutes and mainly wordless as it
concentrates on a single character in an isolated (at first)
environment.
3. *I'll expect to do some color grading, but nothing particularly
fancy. *No compositing or any complicated, CPU-cycle hungry special
effects.
4. *Output from the short will be DVD/blu ray, submitted to genre
festivals (assuming the short doesn't suck)
My goal is to spend as little money as possible while still building
up a system that comfortably suits my needs. *Basically, my goal is
the goal of anyone who's ever built up an editing system.
if you recommend getting a Mac Pro, my preference would be to buy a
used one. *Which era Mac Pro should I buy?
Also, can I get by with Final Cut Pro 6, or will I get a substantial
benefit from paying more for 7?
Thanks in advance for reading this unending post. *I swear I couldn't
think of a shorter way to convey all this info and these questions.
I'd say get one of the new i7 imacs if you don't need portability and they may even be cheaper than a previous gen mac pro yeh with updated tech and a massive screen.
Remember FCS does not have a full option for blu-ray output on disk, you will also need an external blu-ray fw burner too.
You should be able to get by fine with 6 unless you really want 7 and the new flavors of pro res.
Hope some of this helps.
Sounds to me like for this, your macbook will be fine, but if you're planning on doing more shorts, more editing and etc. you can't go wrong buying a Mac Pro. They are work horses and maintain their value well. If you got the money go for it, you can always expand the memory, drive space, cards etc as time goes on with those machines too so you know you can use it for quite sometime to come.
Thanks for the quick replies, guys.
One question: my impression was that FCP does not run on a MacBook (something about the Intel graphics card not being compatible). Also, when I've edited other short videos in Final Cut Express on my MacBook, the rendering times are comically long. If I try to do some color correction, or re-size the output in some way, I have to just set it up to render and then come back 20 minutes later. I can't imagine how frustrating it would be to adjust color/etc. on a series of cuts. in Final Cut Express, let it render for an hour, and then review the work only to find some minor issue that requires re-rendering and waiting all over again.
I'm definitely willing to fork up some money for a machine with more power, but I'm just not sure which way to go. The iMac suggestion confuses me further! My understanding was that iMacs aren't necessarily the best choice for video editing because you can't connect ESATA drives. I guess that wouldn't be an issue with the footage I'd shoot for a 15 minute short, though.
Sean, you mentioned that I can't go wrong getting a Mac Pro. Would you recommend getting a new one, or does it make sense to buy one that's a generation behind (especially if I end up using the older FCP 6)?
One more question: has anybody ever bought a Mac through Apple's refurb program? Is it worth it or should I just go the Craigslist route if I want to get a used mac?
Their refurb program is amazing... they're basically new macs and I've gotten a couple through it and its no problem. The specs of new MacBook Pros are pretty powerful and shouldn't give you any trouble rendering, I think I misunderstood. Do you still have like a white MacBook or something? What are the specs on the one you have? And with iMacs, most of them come with pretty big drives to begin with, like 320 GB or more, and that's usually more than enough for working projects. I usually have whatever projects I'm working on on my comp, and I'm diligent about backing up onto an external HDD when I'm done with the project. So the need to connect eSATA drives isn't too important unless your planning a big documentary or a feature shot in full HD then you're going to have to address that issue. Which is why I would recommend getting the tower.
And yeah there's really no need to get the newest model, grab a quad core slap in some extra RAM and then bam, you got a super fast machine, capable of maxing out at like 16GB ram, 4 TB of disk space (4 drive bays) dual optical drives for superdrive and popping in a BluRay burner if you like... I would definitely go with an older Pro and you won't ever regret it.
