For SALE practically new in immaculate condition the silver M.ZUIKO DIGITAL ED 12mm f/2.0 Lens from Olympus is compatible with the PEN series of interchangeable-lens digital cameras. This lens was given to me as a present last year but I only used it 4 times. I no longer need my photographic equipment due to the fact that I am a senior citizen. These photos were taken this morning.
I am asking $629.00
If you interested, please contact me at (972) 867-3213 or atalis@bluebonnetmediagroup.com
It is a wide-angle prime lens with a focal length of 12mm (35mm equivalent: 24mm). The fast f/2.0 maximum aperture creates a shallow depth of field and is helpful in low-light conditions. The lens' aperture is controlled by a 7-blade circular diaphragm.
The lens combines 11 elements in 8 groups which include DSA, aspherical, Super HR, and ED glass elements, all of which reduce chromatic aberrations for greater clarity and color accuracy. The lens focuses from 7.9" (20 cm) to infinity, and has a maximum reproduction ratio of 1:12.5. It accepts 46mm filters.
The M.ZUIKO DIGITAL ED 12mm f/2.0 features a snap ring allowing you to pan focus with a distance indicator. Its Movie-Still-Compatible (MSC) mechanism ensures that focusing is quiet enough that the sound will not be picked up during video recording. It has a durable full-metal body.
A prime lens, it has a focal length of 12mm (35mm equivalent: 24mm) The wide, fast f/2.0 maximum aperture creates a shallow depth of field and is helpful in low-light conditions. The lens' aperture is controlled by a 7-blade circular diaphragm The lens combines 11 elements in 8 groups which include DSA, aspherical, Super HR, and ED glass elements, all of which minimize chromatic aberrations for greater clarity and color accuracy in your images.
The lens focuses from 7.9" (20 cm) to infinity The maximum reproduction ratio of the lens is 1:12.5
Accepts 46mm filters. The lens features a snap ring allowing you to pan focus with a distance indicator. The Movie-Still-Compatible (MSC) mechanism ensures that focusing is quiet enough that the sound will not be picked up during video recording. Durable full-metal body
SPECIFICATIONS:
What's in the package?:
Olympus M.ZUIKO DIGITAL ED 12mm f/2.0 Lens (Silver)
Front and rear lens caps
Hoya HMC UV (c) 46mm filter
Instruction Manual.
I am asking $629.00
SPECIFICATIONS:
| Focal Length | 12mm Comparable 35mm Focal Length: 24 mm |
| Aperture | Maximum: f/2.0 Minimum: f/22.0 |
| Camera Mount Type | Micro Four Thirds |
| Format Compatibility | Micro Four Thirds |
| Angle of View | 84° |
| Tilt/Shift | Not Specified By Manufacturer |
| Minimum Focus Distance | 7.9" (20.07 cm) |
| Magnification | 0.08x |
| Maximum Reproduction Ratio | 1:13 |
| Elements/Groups | 11/8 |
| Diaphragm Blades | 7 |
Instruction Manual.
