thats odd. They should be almost identical. The GH5 with a Speedbooster Ultra is also a 1.5x crop against FF. Are you sure the lens and sensor were at the same location? Just because two cameras are mounted on the same tripod doesn't mean the sensor and lens are in the same position. It is the physical location of the sensor and lens that determine the FOV and not where it gets mounted to a tripod.
Yes, the Speed Booster does not change the DoF of a given lens, it just puts more light on the sensor, it does not change the F/stop as far as DoFmis concerned. So a f2.8 lens on a SB is still a f/2.8 lens, with the same given DoF at any given subject distance. The focus distance has more to do with DoF at any given f/stop than any other factor.
Cheers
