FS7: LUT not applicable on HDMI output UHD and others minor quirks with GS7
Hello everyone
I have a few quirks with the FS7 and I woudl like to know if it is something I can fix or if I have to live with it.
When shooting CineEI, UHD 25, I can use the hdmi output but there is no way to activate the lut for the hdmi output. It is greyed out.... Is this normal ?
I can have hdmi output on every resolution but one : 4K. When I use 4K, the monitor no longer display a picture.
Alternatively, depending on the resolution or framerate, the output is 1080p or 1080i, and it seems there is no way around it...
Any thought ?
Thank you
The HDMI & SDI2 share the same path so any luts on effect both. If HDMI is greyed out make sure that you have HDMI output turned on.
What I have discovered with my own external monitor is that with 4K at 23.98 (I assume its the same for 25p) is that my old monitor won't read the pull down in the 4K HDMI signal. If I put the monitor on SDI it will display just fine. If I keep it in 4K over HDMI but put it at 30fps my monitor displays the signal.
