mikebarber
Greetings all, I am budgeting out an AF100 camera package that I am about to thrust myself in to years of debt over, and find myself stuck on the issue of what glass to put on it.
I was considering the Lumix G 14-140mm f4.0-5.8 since it is priced just right for me for now and gave me a wide array of focal lengths that seemed to be a good all-purpose lens… then I went and read Barry Green's enlightening write up and now my head is full of FUD.
My immediate need in a lens is something for interviews. Ideally something that would give me the range to go from a medium close shot to a somewhat extreme close shot. I'm still fairly unfamiliar with choosing focal lengths, but what I was thinking (and please correct me if I am wrong, or if you have suggestions) was something to achieve along the lines of 65-75mm (in 35mm terms) for the MCU and somewhere between 100-135mm (in 35mm terms).
Of course, I want to be able to keep a shallow depth of field, which I gather the slow F4.0-5.8 will work against. Any of the f2 zooms that I see are well beyond my price point at the moment (the Olympus zooms seem perpetually on back order anyway).
An option is a to forgo a zoom and get a prime like the Zeiss Planar T* 1,4/50 or 1,4/85, either of which, when combined with a Novoflex MFT/NIK adapter, just hits the margin of my lens budget… or a Sigma EX 30mm f/1.4 or 50mm f/1.4 with the 4/3 to M4/3 adapter would work.
Of course I lose any flexibility with a fixed prime with regards to focal length… ugh, the torment! One work around -- maybe -- is to frame the interview for the MCU with a fixed prime (but which?!) and push in to a CU in post. I am planning on adding the AJA Ki Pro Mini to the kit in order to record ProRes422. You think the sharpness of the prime glass coupled with the high data rate of the ProRes codec will allow for some blowing up without too much noticeable degradation (Isn't that pretty much what Errol Morris does anyway?)
Wow, this turned out to be a much longer post than I intended. If you made it this far, I thank you! :thumbsup:
