1 Lowel DP - includes (2) 750w, (1) 1K bulb, protective screen, ac cable, spare reflector.
The Lowel DP-Light is a powerful workhorse. It's a powerful key, backlight or background light. Add an umbrella or diffusion for soft key or fill light. Swap to the super-spot reflector for long throws, or customize it with a variety of other accessories. The DP is built for a long multi-use life.
This fixture is supplied with a 120 volt AC power cord. Change the cord, or use a plug adapter, and use the DP-Light anywhere in the world with the appropriate bulb.
At B&H with a 1K bulb this light alone costs $166.95. 750w bulbs cost $29.95 each.
1 - Lowel Dichroic Filter for Lowel DP
Converts tungsten (3200K) to the approximate daylight (5500K) color temperature and absorbs U.V. light. The expected light loss is approximately 50% (one f-stop). Requires either the Complete Barndoor or the Barndoor Frame for mounting.
B&H price is $99.95.
1 - Lowel Quartz - the original Lowel DP. Needs to be rewired and have plug replaced. Very sturdy steel light.
1 - Aluminum Case - holds the two lights firmly.
Priced to sell at $200 plus shipping to lower 48 states.
