Low Frame Rates
Oliver Rush
Is there a way to get the AF100 to under-crank below 12fps like the HVX/HPX? I have no tried to hack the scene files yet, but I was wondering if it was a possibility or if anyone had tried it. I miss being able to do time lapses at 2-4fps with the motion blur that you get from a 360degree shutter at that frame rate.
Not through a hack, no -- that doesn't work. But if you use the slow shutter speeds you can get that same effect. 1/2-second shutter speed delivers the exact same look as we used to get from the HVX at 2fps/360-degrees.
